[Qgis-user] Storing and Retrieving Vector Layers with Styles to Postgres DB
    Bo Victor Thomsen
    bo.victor.thomsen at gmail.com
    Mon Apr  7 03:40:59 PDT 2025
Hi Peter -
I'm not sure if you're aware of the "Save style as default" function -
So here comes for a Postgres layer
 1. Load the layer from Postgres
 2. Style the layer
 3. Right-click on the layer name in the "Layers" panel
 4. Click on "Options" -> Button "Style" in the lower leftmost corner of
    the dialog
 5. Click on "Save as Default" option
 6. This will show a small dialog "Load default style from" and 3 buttons
 7. Click the button name "Datasource Database"
 From now on, every time you load the specific table from Postgres as a
QGIS layer, it will automatically gets the saved style.
It not only the style - It's every information associated to the layer:
Field definition, attribute form and more.
Med venlig hilsen / Best regards
Bo Victor Thomsen
On 07/04/2025 08.45, peter.berger--- via QGIS-User wrote:
> There are serveral steps necessary to store from QGIS a vector layer
> with his style in a postgres DB. For a big amout of layers this is
> impracticaI.
> Therfore I would do this in one step from QGIS. Is this in any way
> possible?
> *Peter Berger*
> Brunnwiesenstrasse 62
> 8049 Zürich
> Schweiz
> mobile +41 79 301 71 54
> The several step procedure:
> ·*Load the layer*: Import the layer from a vector file into QGIS.
> ·*Rename (if necessary)*: Give the layer an appropriate name.
> · *Transfer the layer to Postgres*: Drag the layer into the PostgreSQL
> database. You will find it there with the specific name.
> · *Load the layer from Postgres*: Import it back from the PostgreSQL
> database into QGIS.
> · *Assign the style*: Copy the style from the original layer and
> assign it to the Postgres layer loaded in QGIS.
> · *Export the style*: Export the style of the Postgres layer. You will
> now find an option to save the style with the exact name of the layer
> in the PostgreSQL database.
> · *Delete old layers and reload*: Delete all associated layers and
> reload the layer from the PostgreSQL database.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250407/c6460d20/attachment.htm>
More information about the QGIS-User
