[Qgis-user] Storing and Retrieving Vector Layers with Styles to Postgres DB
Jorge Gustavo Rocha
jgr at geomaster.pt
Tue Apr 8 01:54:06 PDT 2025
This is the code I use (since some years ago...) to write styles from
all layers to the database:
mapGeometryType = {
0: "Point",
1: "Line",
2: "Polygon",
3: "UnknownGeometry",
4: "NullGeometry",
layers = QgsProject.instance().mapLayers()
forlayer inlayers.values():
iflayer.type() == QgsMapLayer.VectorLayer:
ifmapGeometryType[layer.geometryType()] != "NullGeometry":
layer.deleteStyleFromDatabase
layer.saveStyleToDatabase(name=layer.name(),description="Default style
for {}".format(layer.name()), useAsDefault=True, uiFileContent="")
Since we are writing all with the flag "default style" there is no need
to load them when opening the project.
Regards,
Jorge Gustavo
On 07/04/25 19:11, Ludwig Kniprath via QGIS-User wrote:
> Hello Peter,
> everything that users do in QGis can be done by Python scripts,
> including your steps listed below.
> There are some difficulties for the desired "one step" solution, f. e.
> the name of the file-based layer must be converted in a valid and
> unique postgis table-name, the fields of the file-based layer must be
> stored with valid postgis field-types and -names and so on...
> Taking into account all special features, exceptions and necessary
> settings, this results in a rather complex program, the implementation
> of which may be more complex than the manual implementation in QGis...
> Just my two cents...
> Ludwig
> Am 07.04.25 um 08:45 schrieb peter.berger--- via QGIS-User:
>> There are serveral steps necessary to store from QGIS a vector layer
>> with his style in a postgres DB. For a big amout of layers this is
>> impracticaI.
>> Therfore I would do this in one step from QGIS. Is this in any way
>> possible?
>> *Peter Berger*
>> Brunnwiesenstrasse 62
>> 8049 Zürich
>> Schweiz
>> mobile +41 79 301 71 54
>> The several step procedure:
>> ·*Load the layer*: Import the layer from a vector file into QGIS.
>> ·*Rename (if necessary)*: Give the layer an appropriate name.
>> · *Transfer the layer to Postgres*: Drag the layer into the
>> PostgreSQL database. You will find it there with the specific name.
>> · *Load the layer from Postgres*: Import it back from the PostgreSQL
>> database into QGIS.
>> · *Assign the style*: Copy the style from the original layer and
>> assign it to the Postgres layer loaded in QGIS.
>> · *Export the style*: Export the style of the Postgres layer. You
>> will now find an option to save the style with the exact name of the
>> layer in the PostgreSQL database.
>> · *Delete old layers and reload*: Delete all associated layers and
>> reload the layer from the PostgreSQL database.
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
*Geomaster, LDA *
*VENHA DESCOBRIR O CAMINHO DO OPEN SOURCE CONNOSC *
Rua Afonso Palmeira, 31, 7 D
4715-278 Braga
VAT/NIF 510 906 109
Phone +351 253 257 173
Site geomaster.pt <http://geomaster.pt>
GPS 41.54627, -8.40432
Logo
Jorge Gustavo Rocha
CTO
Mobile +351 910 333 888
Email jgr at geomaster.pt
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250408/4e701527/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250408/4e701527/attachment-0001.png>
More information about the QGIS-User
