[Qgis-user] Storing and Retrieving Vector Layers with Styles to Postgres DB
Etienne Trimaille etienne.trimaille at gmail.com
Tue Apr 8 09:18:08 PDT 2025
The code from Jorge does the job for ALL layers in the current project, can
you describe your issue Peter ?
Le mar. 8 avr. 2025 à 17:51, peter.berger--- via QGIS-User <
qgis-user at lists.osgeo.org> a écrit :
> Hi Jorge
> For me it is too minimal with this code alone. Would it be possible to
> describe how to run it when I have 65 Layers with styles and like to bring
> it all with styles to the postgres DB?
> Many thanks in advance.
> Peter
> Von meinem iPhone gesendet
> Am 08.04.2025 um 10:59 schrieb Jorge Gustavo Rocha via QGIS-User <
> qgis-user at lists.osgeo.org>:
> Hi,
> This is the code I use (since some years ago...) to write styles from all
> layers to the database:
> mapGeometryType = {
> 0: "Point",
> 1: "Line",
> 2: "Polygon",
> 3: "UnknownGeometry",
> 4: "NullGeometry",
> layers = QgsProject.instance().mapLayers()
> for layer in layers.values():
> if layer.type() == QgsMapLayer.VectorLayer:
> if mapGeometryType[layer.geometryType()] != "NullGeometry":
> layer.deleteStyleFromDatabase
> layer.saveStyleToDatabase(name=layer.name(),description="Default style
> for {}".format(layer.name()), useAsDefault=True, uiFileContent="")
> Since we are writing all with the flag "default style" there is no need to
> load them when opening the project.
> Regards,
> Jorge Gustavo
> On 07/04/25 19:11, Ludwig Kniprath via QGIS-User wrote:
> Hello Peter,
> everything that users do in QGis can be done by Python scripts, including
> your steps listed below.
> There are some difficulties for the desired "one step" solution, f. e. the
> name of the file-based layer must be converted in a valid and unique
> postgis table-name, the fields of the file-based layer must be stored with
> valid postgis field-types and -names and so on...
> Taking into account all special features, exceptions and necessary
> settings, this results in a rather complex program, the implementation of
> which may be more complex than the manual implementation in QGis...
> Just my two cents...
> Ludwig
> Am 07.04.25 um 08:45 schrieb peter.berger--- via QGIS-User:
> There are serveral steps necessary to store from QGIS a vector layer with
> his style in a postgres DB. For a big amout of layers this is impracticaI.
> Therfore I would do this in one step from QGIS. Is this in any way
> possible?
> *Peter Berger*
> Brunnwiesenstrasse 62
> 8049 Zürich
> Schweiz
> mobile +41 79 301 71 54
> The several step procedure:
> ·  *Load the layer*: Import the layer from a vector file into QGIS.
> ·  *Rename (if necessary)*: Give the layer an appropriate name.
> ·  *Transfer the layer to Postgres*: Drag the layer into the PostgreSQL
> database. You will find it there with the specific name.
> ·  *Load the layer from Postgres*: Import it back from the PostgreSQL
> database into QGIS.
> ·  *Assign the style*: Copy the style from the original layer and assign
> it to the Postgres layer loaded in QGIS.
> ·  *Export the style*: Export the style of the Postgres layer. You will
> now find an option to save the style with the exact name of the layer in
> the PostgreSQL database.
> ·  *Delete old layers and reload*: Delete all associated layers and
> reload the layer from the PostgreSQL database.
> QGIS-User mailing listQGIS-User at lists.osgeo.org
> * Geomaster, LDA *
> * VENHA DESCOBRIR O CAMINHO DO OPEN SOURCE CONNOSC *
> Rua Afonso Palmeira, 31, 7 D
> 4715-278 Braga
> VAT/NIF 510 906 109
> Phone   +351 253 257 173
> Site geomaster.pt
> GPS 41.54627, -8.40432
> <cropped-geomaster300x300-1.png>
> Jorge Gustavo Rocha
> CTO
> Mobile   +351 910 333 888
> Email    jgr at geomaster.pt
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250408/ed886fe6/attachment.htm>
More information about the QGIS-User mailing list
