[Qgis-user] georeference intersecting lines of highway map
Greg Troxel gdt at lexort.com
Sun Apr 20 11:25:22 PDT 2025
"John W. Blue via QGIS-User" <qgis-user at lists.osgeo.org> writes:
> I have downloaded historical highway maps in .png format that I would
> like to georeference.
Very cool; consider publishing the georeferenced versions.
> Around the perimeter of the map are a few lines indicating lat and
> long making it easy to be able to add a layer to draw straight lines
> from left to right and from top to bottom.  Which I was able to do.
> From there I was able to get QGIS to find the intersections.
> And now I am stuck because I cannot save the intersections with
> lat/long coordinates it only allows x,y.
> I am sure I am most likely doing something wrong out of the gate but
> this seems like the logical direction to go in.
The old maps have "lat and long", but what datum?  Depends on where and
how old.  Basically pre-80/90s coordinates were different enough from
modern ITRF that it is likely to be noticeable.
I would just use the georeferencer in qgis against either imagery or
openstreetmap and find a bunch of intersections.  That throws away the
original lat/long information but avoids "it is in NAD27" or "it is in
the New England Datum" or however that is for where you are looking at.
More information about the QGIS-User mailing list
