[Qgis-user] georeference intersecting lines of highway
Greg Troxel
gdt at lexort.com
Sun Apr 20 16:11:01 PDT 2025
Garth Fletcher via QGIS-User <qgis-user at lists.osgeo.org> writes:
> I think you have to know the projection used for the printed map, and
> then set that layer's CRS to match.
> Then you can convert ("warp") it to your preferred (project) CRS.
> The problem is that different projections distort the map in different
> ways, for example conical vs mercator projections.
> In such cases if you simply import a conical projected map, say of
> Massachusetts, as a raster into your transverse mercator project, say
> for New Hampshire, the result will be doubly distorted...
A fair point.
I was thinking of large-scale maps and conformal projections, which are
probably more forgiving.
More information about the QGIS-User
