[Qgis-user] XYZ tiles in CRS other than web Mercator
Richard Greenwood
richard.greenwood at gmail.com
Wed Apr 23 14:25:11 PDT 2025
I don't have a TMS z/y/x data set to play with but I do have a vector
tile {z}/{x}/{y}.pbf data set that's not in epsg:3857 which I had some
limited success with when I set both the layer and the project coord system
to that of the tile source. By "limited success" I mean that it was in the
right place, however the zoom levels are not correct. The OpenLayers
configurations that consume these tiles have custom min/max resolutions
defined, not web mercator zoom levels. And I don't see how to accomplish
that in QGIS.
On Wed, Apr 23, 2025 at 1:37 PM Árni Geirsson <arni at alta.is> wrote:
> I am referring to TMS, stored in a directory structure (/z/y/x) on a
> simple web server, not WMTS where a capabilities response is available.
> Tile sets are sometimes generated for specific projections for use in web
> maps that are presented in that projection, such as a national CRS. I
> assume this is why Openlayers allows map views to be defined in any
> projection and tile layers included in that same projection to minimize the
> need for reprojection on the fly.
> I am not sure I can disclose the URL of the tile set I am considering, but
> the url looks just like a regular XYZ url designed for web mercator, it is
> just the X, Y and Z values that are very different in the given projection.
> So the basic question is: Can I use such tile sets in QGIS just as I would
> be able to use them in Openlayers?
> Arni
> On Wed, 23 Apr 2025 at 19:26, Greg Troxel via QGIS-User <
> qgis-user at lists.osgeo.org> wrote:
>> Patrick Dunford via QGIS-User <qgis-user at lists.osgeo.org> writes:
>> > I honestly don't know that you have any option to use other than
>> > EPSG3857 for webtiles. It's practically baked into the webtile
>> > specifications.
>> I am not sure if the OP is talking about TMS or WMTS:
>> https://www.ogc.org/standards/wmts/
>> With the phrase XYZ tiles, I suspect TMS:
>> https://en.wikipedia.org/wiki/Tile_Map_Service
>> As I understand it, TMS is 3857, and WMTS can carry a CRS.
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Richard W. Greenwood
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250423/db310f2f/attachment.htm>
More information about the QGIS-User
