[Qgis-user] relation reference filter
Vedran Stojnović phidrho at gmail.com
Thu Apr 24 22:42:37 PDT 2025
Did you set up relational widgets properly?
There is a good tutorial in the official docs:
https://docs.qgis.org/3.40/en/docs/user_manual/working_with_vector/joins_relations.html#many-to-many-n-m-relations
čet, 24. tra 2025. u 22:05 Kosza Antal via QGIS-User <
qgis-user at lists.osgeo.org> napisao je:
> chris hermansen <clhermansen at gmail.com> ezt írta (időpont: 2025. ápr.
> 24., Cs, 20:07):
>> Kosza and list,
>> On Thu, Apr 24, 2025 at 3:34 AM Kosza Antal via QGIS-User <
>> qgis-user at lists.osgeo.org> wrote:
>>> Hello everyone,
>>> I want to implement the following in qgis
>>> Given 3 geopackage tables, one is the findings, the second is the type,
>>> the third is the material, and the fourth is the findings_material. The
>>> latter is a connecting table between the type and the material. The tables
>>> refer to each other with foreign keys. The foreign key is of type uuid.
>>> The task: in qgis, the findings table needs to be edited, the findings
>>> field refers to the type uuid with a foreign key, the material field refers
>>> to the uuid key of the material table. qgis automatically recognizes the
>>> relationships and sets up a relation reference widget.
>>> What I want: when I select the finding, i.e. the corresponding value
>>> from the type table, in the material it should filter the values based on
>>> the pivot table.
>>> This is how it looks in sql.
>>> SELECT
>>> a.uuid AS material_uuid,
>>> a.values AS material_values
>>> FROM
>>> material AS a
>>> JOIN
>>> result_material AS pivot ON a.uuid = pivot.material_fk
>>> WHERE
>>> pivot.characteristic_fk = '6c5356d0-3257-49ed-8f95-4262d33175c9';
>>> Just wondering if you could create a view based on your SELECT statement
>> that is editable (I've not done this in SQLite so I have no idea if it's
>> possible).
>> Looking at your SQL vs your description, I'm not following.  You say "the
>> findings table needs to be edited"... Then it seems to me you need a SELECT
>> statement like this:
>> SELECT f.*,t.*,m.*
>> FROM findings AS f
>> JOIN type AS t ON f.type_uuid = t.uuid
>> JOIN material AS m ON f.material_uuid = m.uuid
>> I don't understand the purpose of the table you call "findings_material"
>> in one place and "result_material" in another and which you say is "a
>> connecting table between the type and the material".  It seems to me the
>> findings table connects type and material (as per my SELECT statement).
>> Are you using it to restrict the combinations of type and material?  If
>> that's the case, then you should probably relate the findings table to that
>> restricting table rather than type and material directly.  I would probably
>> choose to call that restricting table something like
>> "allowed_type_material" and have a field on findings that was called
>> "allowed_type_material_uuid".
>> Sorry that I'm not finding your problem description clear; I hope my
>> comments don't add confusion.
>> Chris Hermansen · clhermansen "at" gmail "dot" com
>> C'est ma façon de parler.
> Sorry, I really worded it confusingly, the table names are in Hungarian, I
> overlooked something, let me clarify
> The main table is the findings, in which the "type" column is a foreign
> key to the "uuid" column of the types table, the material column is a
> foreign key to the "uuid" column of the material table
> 1. table - findings
> 2. table - types
> 3. table - material
> 4. table - findings material (connecting table), N:M relationship
> The sql query:
> SELECT
> FROM
> material AS a
> JOIN
> findings_material AS pivot ON a.uuid = pivot.material_fk
> WHERE
> pivot.types_fk = '6c5356d0-3257-49ed-8f95-4262d33175c9';
> All this is being done for a qfield project,.
> I would like to solve the result of this sql query during data collection,
> that is, I create a point with gps, select the type of the find, and in the
> material column, only those values are displayed that are assigned to this
> type in the connection table.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Srdačan pozdrav / Kind regards,
Vedran Stojnović.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250425/91c77e6b/attachment.htm>
More information about the QGIS-User mailing list
