[Qgis-user] How do you see which transform is being used for a given projection?
John Stevenson - BGS
jostev at bgs.ac.uk
Fri Aug 8 00:48:55 PDT 2025
Thanks Andrea,
I found the information in in Project -> Properties -> Transformations, as you suggested.
(I didn't know that tab existed and had been looking in Project -> Properties -> CRS)
Regards,
John
-----Original Message-----
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of Andrea Giudiceandrea via QGIS-User
Sent: 08 August 2025 00:05
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] How do you see which transform is being used for a given projection?
> John Stevenson - BGS jostev at bgs.ac.uk Thu Aug 7 05:02:32 PDT 2025
> When I add a layer with OSGB36 (epsg:27700) projection to a project in QGS84 (epsg:4326), I am given an option to select the coordinate transformation to use. There are multiple options: https://epsg.io/27700. The best includes a custom correction grid, OSTN15_NTv2.
> Once the layer has been added, is there a way to see which transformation was used?
Hi John,
you should find chosen datum transformation in "Settings -> Options -> CRS and Transforms -> Coordinate Transforms" and /or "Project -> Properties -> Transformations".
Please see:
https://docs.qgis.org/latest/en/docs/user_manual/introduction/qgis_configuration.html#transformations-properties
https://docs.qgis.org/latest/en/docs/user_manual/introduction/qgis_configuration.html#transformations-options
https://docs.qgis.org/latest/en/docs/user_manual/working_with_projections/working_with_projections.html#datum-transformations
Regards.
Andrea
QGIS-User mailing list
QGIS-User at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
More information about the QGIS-User
