[Qgis-user] Placing group of image at once
Andreas Neumann
andreas at qgis.org
Wed Aug 20 09:16:02 PDT 2025
Hi Léopold,
These are "top-view" images - right? Taken from a drone? Or a special rail
coach and a
Maybe you can mosaic the images with some photogrammetry software and
create GeoTIFF images?
The display performance of many thousand individual images (each on its
own) might not perform / scale too well?
Greetings,
Andreas
On Wed, 20 Aug 2025 at 16:20, Léopold Stoessel via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hello,
> Our team is currently working on a project to reconstruct the railways of
> Canada using QGIS. To do this, we collect data directly on the rails,
> taking a photo every 2 meters. Each image (JPG) is accompanied by an XML
> file containing its GPS coordinates (EPSG:4326) and orientation.
> Our goal is to display all the images on a QGIS map at their correct
> geographic location and with the proper orientation. (Example image:
> *Try.jpg*)
> As far as I understand, a JPG file needs either an associated PGW world
> file or must be converted into a georeferenced TIFF in order to be
> correctly placed on the map.
> Here are the challenges we're facing:
> - *PGW method*: I tried placing a PNG file with a PGW of the same name
> in the same directory, but QGIS seems to ignore the PGW file and creates
> HTML document with other coordinates instead.
> - *GeoTIFF method*: With over 500,000 images, manually georeferencing
> each one is not feasible.
> So I would like to ask for your advice:
> - Are we on the right track with our approach?
> - Which method would you recommend in our case?
> - Do you know of any way to automate the image placement and
> orientation based on our XML data?
> - Would it be possible to handle this through the Python console or
> using PyQGIS?
> Any guidance or suggestions would be greatly appreciated.
> Thanks in advance for your time and help!
> <https://www.cefrail.ca/> <https://www.facebook.com/cefrail>
> <https://www.linkedin.com/authwall?trk=bf&trkInfo=AQEjKKnHH0hB2QAAAYzqp8YogvhljVV4rfWfPZk4nt7Fxp7t-jgeC03T84SUqgFnFtN8YLHip3me96M7mf832Uiq6YnFyyw3y1AU8c10Tw4twclYPuLl6KexU9lj_p4Hp_UeifI=&original_referer=&sessionRedirect=https%3A%2F%2Fwww.linkedin.com%2Fcompany%2Fcefrail>
> *Léopold Stoessel*
> Stagiaire - Génie ferroviaire
> 1 866 544-RAIL
> *leopold.stoessel at cegepsi.ca <leopold.stoessel at cegepsi.ca>*
> *www.cefrail.ca <http://www.cefrail.ca/> *
> *RAIL est un centre intégré au Cégep de Sept-Îles*
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Andreas Neumann
QGIS.ORG board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250820/1000a210/attachment.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250820/1000a210/attachment.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250820/1000a210/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250820/1000a210/attachment-0001.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250820/1000a210/attachment-0002.png>
More information about the QGIS-User
