[Qgis-user] Placing group of image at once
Kirk Schmidt
kirk at nortekresources.com
Thu Aug 21 06:15:03 PDT 2025
Hi All:
I believe these will be oblique photo's and therefore not georeferenced
in the traditional sense. Therefor, world files would not work as they
are not designed to handle perspective geometry. I believe geotiffs
can handle perspective geometry.
Good Luck
Kirk Schmidt
On 8/20/2025 7:04 PM, Richard Duivenvoorde via QGIS-User wrote:
> Hi,
> Looks like a fun project.
> Can you provide the accompanying xml file for 'Try.jpg'?
> Because if you can create some script to convert that Try.xml to
> Try.wld (or whatever extension gdal/QGIS wants for a jpeg world file),
> you can maybe create a mosaic geotiff from it, though it will be
> HUGE...).
> Looking at: https://gdal.org/en/stable/drivers/raster/jpeg.html GDAL
> (the lib that loads rasters for QGIS, expects .jgw, .jpgw/.jpegw or
> .wld suffixes, not PGW ???)
> There is also a 'vrt' (GDAL Virtual Format) for all your jpg+wld files
> (https://gdal.org/en/latest/drivers/raster/vrt.html).
> Normally you will create a 'shapefile' then with the extents of all
> the images, which is then used as spatial index for gdal.
> Not sure if that can take into account rotation though.
> Hopefully somebody has some info about that.
> Last option could be, depending on the names of the xml and jpg files
> to do this loading 'on the fly' using some pyqgis... Like find all
> files in current extent and (by reading/interpreting the xml files)
> create the wld file on the fly and load every jpg+wld as layer...
> Also you do want to view all the raster/photo's as rasters, yes? Not
> as vector points with a popup showing the (rotated?) image?
> See what others come up with?
> It IS a lot of data to play with though :-)
> Regards,
> On 20-08-2025 16:20, Léopold Stoessel via QGIS-User wrote:
>> Hello,
>> Our team is currently working on a project to reconstruct the
>> railways of Canada using QGIS. To do this, we collect data directly
>> on the rails, taking a photo every 2 meters. Each image (JPG) is
>> accompanied by an XML file containing its GPS coordinates (EPSG:4326)
>> and orientation.
>> Our goal is to display all the images on a QGIS map at their correct
>> geographic location and with the proper orientation. (Example image:
>> /Try.jpg/)
>> As far as I understand, a JPG file needs either an associated PGW
>> world file or must be converted into a georeferenced TIFF in order to
>> be correctly placed on the map.
>> Here are the challenges we're facing:
>> * *PGW method*: I tried placing a PNG file with a PGW of the same
>> name in the same directory, but QGIS seems to ignore the PGW file and
>> creates HTML document with other coordinates instead.
>> * *GeoTIFF method*: With over 500,000 images, manually
>> georeferencing each one is not feasible.
>> So I would like to ask for your advice:
>> * Are we on the right track with our approach?
>> * Which method would you recommend in our case?
>> * Do you know of any way to automate the image placement and
>> orientation based on our XML data?
>> * Would it be possible to handle this through the Python console or
>> using PyQGIS?
>> Any guidance or suggestions would be greatly appreciated.
>> Thanks in advance for your time and help!
>> ** <https://www.cefrail.ca/>**
>> <https://www.facebook.com/cefrail>**<https://www.linkedin.com/authwall?trk=bf&trkInfo=AQEjKKnHH0hB2QAAAYzqp8YogvhljVV4rfWfPZk4nt7Fxp7t-jgeC03T84SUqgFnFtN8YLHip3me96M7mf832Uiq6YnFyyw3y1AU8c10Tw4twclYPuLl6KexU9lj_p4Hp_UeifI=&original_referer=&sessionRedirect=https%3A%2F%2Fwww.linkedin.com%2Fcompany%2Fcefrail>
>> *Léopold Stoessel*
>> Stagiaire - Génie ferroviaire
>> 1 866 544-RAIL
>> _leopold.stoessel at cegepsi.ca <mailto:leopold.stoessel at cegepsi.ca>_
>> _www.cefrail.ca <http://www.cefrail.ca/> _
>> /RAIL est un centre intégré au Cégep de Sept-Îles/
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Kirk Schmidt, MScF, BScF, RPF
General Manager
Nortek Resource Solutions Inc.
26 Church Road
Sutherlands River, NS
B0K 1W0
Tel (902) 922.3607
Email: kirk at nortekresources.com
Web: www.nortekresources.com
More information about the QGIS-User
