[Qgis-user] Projection Problems
boxerg at iinet.net.au boxerg at iinet.net.au
Mon Dec 8 01:31:06 PST 2025
I was wondering if anyone else has been having problems with QGIS not
displaying images when they are if a different projection to the map window.
For example, when the map window is in WGS84 LL and the image is in WGS84
UTM z11n, the image does not display until I change the map window to the
image's native projection. Just wondering if this is just me or could there
be problems with the projection data in the file. Images are from USGS
EartData search portal.
Cheers Grant, Perth WA
More information about the QGIS-User mailing list
