[Qgis-user] Creating a 3D line with measure included
Andrea Giudiceandrea andreaerdna at libero.it
Tue Dec 9 01:41:23 PST 2025
> Jeroen de Jong - Periplus Group j.d.jong at periplus.nl
> Tue Dec 9 00:48:59 PST 2025
> My logic was to use 'Points to Path' to create a line with these elements, unfortunately the M value is not included.
Hi Jeroen,
which QGIS version are you using exactly? Which WKT type is the input
point layer?
AFAIK the "Points to Path" (native:pointstopath) processing algorithm
correctly adds the M value to the output line vertices if the input
points have an M value as you can see in the screen recording available
at https://jumpshare.com/s/5J2ipdRIijEiNJUkTTmO.
Regards.
Andrea
More information about the QGIS-User mailing list
