[Qgis-user] problème lors de l'export d'un nuage de points (LIDAR HD) en MNT
Pascal WISSENBERG p.wissenberg at orange.fr
Sun Dec 14 06:21:24 PST 2025
Hi Andrea,
I installed version 3.40.4 ltr and when I use the same "export to
raster" algorithm, I get a new message:
/QGIS Version: 3.40.4-Bratislava
Code Revision: 4dd7d7e969
Qt Version: 5.15.13
Python Version: 3.12.9
GDAL Version: 3.10.2
GEOS Version: 3.13.0-CAPI-1.19.0
Proj Version: Rel. 9.5.1, December 1st, 2024
PDAL version: 2.8.3 (git-version: 56e405)
Algorithm started at: 2025-12-14T14:13:01
Starting algorithm 'Export to raster (using triangulation)'…
Input parameters:
{ 'FILTER_EXPRESSION' : 'Classification = 2 OR 6', 'FILTER_EXTENT' :
None, 'INPUT' : 'copc://E:/My Documents/QGIS/LIDAR
tiles/LHD_FXX_0801_6398_PTS_LAMB93_IGN69.copc.laz', 'ORIGIN_X' : None,
'ORIGIN_Y' : None, 'OUTPUT' : 'E:/My Documents /QGIS/dalles
MNT/0801-6398k.tif', 'RESOLUTION': 0.05, 'TILE_SIZE': 1000 }
wrench command: C:/program files/QGIS
3.40.4/apps/qgis-ltr/./pdal_wrench.exe to_raster_tin "--input=E:/My
Documents/QGIS/LIDAR slabs/LHD_FXX_0801_6398_PTS_LAMB93_IGN69.copc.laz"
"--output=E:/Mes Documents/QGIS/dalles MNT/0801-6398k.tif"
--resolution=0.05 --tile-size=1000 "--filter=Classification == 2 ||
The process stopped so unexpected
Execution failed after 2.89 seconds
Loading result layers
The following layers were not generated correctly.
• E:/My Documents/QGIS/dalles MNT/0801-6398k.tif
You can check the 'Log Messages Panel' in the QGIS main window to find
more information about the algorithm execution./
Thank you in advance for your suggestion.
Best regards.
PW
>> Sat Dec 13 01:51:31 PST 2025
>> j'utilise QGis 3.34.5 et depuis quelques jours, lorsque je veux
>> exporter un fichier LIDARHD de l'IGN vers un raster (en utilisant la
>> triangulation) pour obtenir un fichier MNT, j'ai un retour:
>> /Warning 1: Can't open E:/ Mes Documents/QGIS/ Dalles
>> MNT\0887-6754m\0_0.tif. Skipping it/     par exemple.
> Hi Pascal,
> actually you are using QGIS 3.44.5, according to the provided log.
> Unfortunately, it looks like there is an issue when using the PDAL
> "Export to raster (using triangulation)" processing algorithm running
> the QGIS 3.44.5 and QGIS LTR 3.40.13 on Windows in order to convert a
> COPC file to a GeoTIFF file.
> You should be able to perform the conversion on Windows 10 running a
> previous QGIS version, like QGIS LTR 3.40.7 [1].
> Best regards.
> [1] https://qgis.org/downloads/QGIS-OSGeo4W-3.40.7-1.msi
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251214/6d3ff1e5/attachment-0001.htm>
More information about the QGIS-User mailing list
