[Qgis-user] Projection Problems
Grant Boxer boxerg at iinet.net.au
Tue Dec 16 18:04:05 PST 2025
I will try to create it and describe what I do and when the problem occurs.
Cheers Grant
-----Original Message-----
From: Andrea Giudiceandrea <andreaerdna at libero.it>
Sent: Wednesday, 17 December 2025 8:51 AM
To: qgis-user at lists.osgeo.org
Cc: boxerg at iinet.net.au
Subject: Re: [Qgis-user] Projection Problems
> Tue Dec 16 15:34:09 PST 2025
> This has been an on-going issue for the past few releases. The workaround is to open the images in their native projection. Not sure if is a proj issue or a QGIS issue.
Hi Grant,
if you think that it is a bug, even more so if the issue didn't occur in previous versions, so it would be a regression, I suggest you to report the issue to https://github.com/qgis/QGIS/issues (if not already
reported) in order to be investigated and fixed if needed.
Regards.
Andrea
More information about the QGIS-User mailing list
