[Qgis-user] Applying a label to a point in a series of points
Phil phillor9 at gmail.com
Sat Dec 20 15:02:13 PST 2025
On 11/28/25 08:10, Brent Wood wrote:
> Hi & welcome...
> I find this aspect is better addressed as a data management issue
> rather that a labelling one.
> If your data is managed in database tables (Postgis, Spatialite,
> MariaDB/MySQL are the obvious free ones that work well with QGIS) then
> appending new points to existing lines and making lines from points is
> simple spatial data management. You can also set up a "view" -
> essentially a stored query acting like a physical table of data -
> returning, for example, the last point in a linestring.
Thank you Brent for taking the time to reply.
In the past three weeks since my first posting I managed to collect,
over a ten hour period, roughly 250 aeroplane positions. I used Python
to extract the data needed and assemble the result into a CSV file. This
doesn't occur in real time.
Many of the aeroplanes were only received once and so I wasn't able to
plot a track for those aeroplanes and not all reception reports were
complete resulting in track errors.
I'm only vaguely familiar with SQL and haven't used it, or even thought
about it, since my university days and I'm now in my late seventies. I'm
not sure, at the moment, how a database would benefit my project but
I'll give it some more thought. Maybe I can feed live data into MySql?
Now, after a few minutes of thought, I may be able to feed an SQL query
into QGIS in real time. Another project to play with.
Regards,
Phil
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251221/58516ff6/attachment.htm>
More information about the QGIS-User mailing list
