[Qgis-user] Saving selections as new layer
Alexandre Neto
senhor.neto at gmail.com
Sat Dec 20 23:24:09 PST 2025
Select the features you want. In the layers panel, right-click the layer
and in the context menu select Export > Save Selected Features. A dialog
appears which allows you to select the output format and other options.
Alternatively, you can also use the Extract by Expressing tool from the
processing toolbox.
https://docs.qgis.org/3.40/en/docs/user_manual/processing_algs/qgis/vectorselection.html#extract-by-expression
Just select the "selected features only" option and use 1 ( which represent
true) in the expression. The advantages of this approach is that, if you
want, you can create the new layer as a temporary layer.
Best regards,
Alexandre Neto
www.aneto.pt
A sábado, 20/12/2025, 23:15, Garth Fletcher via QGIS-User <
qgis-user at lists.osgeo.org> escreveu:
> Select (highlight in Layers) the layer from which you want to copy
> features,
> use selection tool to select states,
> Edit > Copy,
> then select (highlight in Layers the target layer
> click on pencil ("Toggle Editing") to make it editable,
> then Edit > Paste
> Note: if you want to Copy into a layer that doesn't yet exist
> then first use Layer > Create Layer to create a new layer in Layers.
> Of course it needs to be of the same type as the layer your want to
> copy from...
> Then proceed as above.
> Garth Fletcher
> On 12/20/25 Mike Breiding <epicroadtrips at gmail.com> wrote:
> > Greetings,
> > When I select several states at once from a US layer, how do I save
> > those selections to a new layer?
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251221/ae1f16e2/attachment.htm>
More information about the QGIS-User
