[Qgis-user] Applying a label to a point in a series of points - solved
Andrea Giudiceandrea andreaerdna at libero.it
Sun Dec 21 12:44:43 PST 2025
> Phil phillor9 at gmail.com
> Sun Dec 21 12:12:14 PST 2025
> Thank you Andrea, I didn't know that statements such as "if" and
> "maximum" are available and can be used just like any programming language.
You are welcome.
You can find more info about using expressions in QGIS at
https://docs.qgis.org/latest/en/docs/user_manual/expressions/expression.html
and
https://docs.qgis.org/latest/en/docs/user_manual/expressions/functions_list.html
> Anyway, once I discovered the marker attributes first and last vortex
> the problem was solved.
AFAIK, that is an option for symbolising line layers (e.g. displaying a
marker only at first and last vertices) not for labelling only the first
and last point in a series of points.
Regards.
Andrea
More information about the QGIS-User mailing list
