[Qgis-user] reduce number of open files in pyqgis script
Ludwig Kniprath
ludwig at kni-online.de
Sun Dec 28 09:06:47 PST 2025
Hi Martin,
I just fiddled with QgsProviderRegistry and noticed, that
"querySublayers" returns a bunch of GPKG-internal-views and -indices,
that are processed in your script, although not containing any clippable
vector data.
Workaround 1: Use osgeo.ogr.Open() to get a list of real
vector-sub-layers and reduce the number of layer-creations,
clip_layer-calls and open files
Workaround 2: Use osge.ogr to do the layer-creation and clip
(sadly beyond my knowledge...)
gpkg_path = "/home/martin/geodata/ZABAGED20251006.gpkg"
# variant with QgsProviderRegistry.instance().querySublayers(...)
gpkg_sub_layer_names = [gpkg_sub_layer_details.name() for
gpkg_sub_layer_details in
QgsProviderRegistry.instance().querySublayers(gpkg_path)]
print(len(gpkg_sub_layer_names))
print(gpkg_sub_layer_names)
# variant with osgeo.ogr.Open(...)
from osgeo import ogr
gpkg_real_sub_layer_names = [gpkg_sub_layer.GetName() for gpkg_sub_layer
in ogr.Open(gpkg_path)]
print(len(gpkg_real_sub_layer_names))
print(gpkg_real_sub_layer_names)
hth
Ludwig
Am 26.12.25 um 12:24 schrieb Martin Landa via QGIS-User:
> Dear all,
> I have a standalone pyqgis script which processes multiple layers
> stored in a single GPKG. The first part of the script loops over
> layers, performs clipping by extent and stores the result in a
> memory layer. The problem which I am facing is the increasing number
> of open files which easily reach the OS limit. The sample script:
> import sys
> import psutil, os
> import gc
> from qgis.core import QgsProviderRegistry, QgsVectorLayer,
> QgsRectangle, QgsFeatureRequest, QgsWkbTypes, QgsFeature, QgsGeometry
> def open_files_count():
> return len(process.open_files())
> def clip_layer(layer: QgsVectorLayer, extent: QgsRectangle,
> layer_name: str) -> QgsVectorLayer:
> extent_geom = QgsGeometry.fromRect(extent)
> clipped_layer = QgsVectorLayer(
> f"{QgsWkbTypes.displayString(layer.wkbType())}?crs={layer.crs().authid()}",
> layer_name,
> "memory"
> clipped_layer.dataProvider().addAttributes(layer.fields())
> clipped_layer.updateFields()
> for feature in
> layer.getFeatures(QgsFeatureRequest().setFilterRect(extent)):
> geom = feature.geometry()
> if geom.intersects(extent_geom):
> clipped_feature = QgsFeature()
> clipped_feature.setGeometry(geom.intersection(extent_geom))
> clipped_feature.setAttributes(feature.attributes())
> clipped_layer.dataProvider().addFeature(clipped_feature)
> clipped_feature = None
> clipped_layer.commitChanges()
> return clipped_layer
> process = psutil.Process(os.getpid())
> layers = QgsProviderRegistry.instance().querySublayers(gpkg_path)
> extent = QgsRectangle(-653547, -1065864, -653225, -1065600)
> clipped_layers = []
> for sublayer in layers:
> name = sublayer.name <http://sublayer.name>()
> layer = QgsVectorLayer(sublayer.uri(), 'ogr')
> clipped_layer = clip_layer(layer, extent, layer.name
> <http://layer.name>())
> del layer
> print(name, open_files_count())
> if clipped_layer.featureCount() == 0:
> del clipped_layer
> continue
> clipped_layers.append(clipped_layer)
> When launching the script number of open file is increasing regardless
> any attempts to release data sources (del layer, layer = None,
> gc.collect(), ...):
> ZeleznicniStaniceZastavka 3
> ZeleznicniPrejezd_b 4
> ZdrojPodzemnichVod 5
> BazinaMocal 172
> ArealZeleznicniStaniceZastavky 173
> ArealUceloveZastavby 174
> Please how to release data sources correctly to avoid increasing the
> number of open files?
> Thanks in advance, Martin
> Martin Landa
> https://geomatics.fsv.cvut.cz/en/employees/martin-landa/
> https://gismentors.cz/mentors/landa
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251228/84f59961/attachment-0001.htm>
More information about the QGIS-User
