[Qgis-user] Least Cost Path
chris hermansen clhermansen at gmail.com
Tue Feb 4 13:47:12 PST 2025
Krishna and list,
On Tue, Feb 4, 2025 at 12:43 PM krishna Ayyala <ayyalakrishna at gmail.com>
wrote:
> Chris,
> Its nothing to do with the number of points. I got the same error when I
> ran with 160 points.I also went to the study manual of v.net.salesman. The
> network and points are as per their guidelines.
> [image: image.png]
These are different errors.  You are supplying at least one incorrect input
argument (see the <points> is not a valid parameter) and your input file
"outputla.. etc..." is not found.
I don't know what else to say, these messages seem pretty self-explanatory
and there's no other info here to work with.
> On Tue, Feb 4, 2025 at 1:08 PM chris hermansen <clhermansen at gmail.com>
> wrote:
>> Krishna and list,
>> On Tue, Feb 4, 2025 at 11:49 AM krishna Ayyala <ayyalakrishna at gmail.com>
>> wrote:
>>> I also ran v.clean on the network. Then ran v.net.salesman on the
>>> cleaned network. That did not help. Getting the same error message. Is
>>> there a fix for this? I wish to run  v.net.salesman without any errors.
>>> On Tue, Feb 4, 2025 at 12:15 PM krishna Ayyala <ayyalakrishna at gmail.com>
>>> wrote:
>>>> Chris,
>>>> Again thanks for your reply. I am not sure if my network is proper. I
>>>> downloaded this from an online data source. How to fix it, if there are any
>>>> errors? Are there any tools in qgis to fix this?
>>>> Regards.
>>>> On Tue, Feb 4, 2025 at 12:12 PM chris hermansen <clhermansen at gmail.com>
>>>> wrote:
>>>>> Krishna and list,
>>>>> On Tue, Feb 4, 2025, 10:49 krishna Ayyala <ayyalakrishna at gmail.com>
>>>>> wrote:
>>>>>> Chris,
>>>>>> Alternatively, I ran v.net.salesman. Even that is giving following
>>>>>> error.
>>>>>> [image: image.png]
>>>>>> [image: image.png]
>> Look at the message - Number of cities: 0 / ERROR: Not enough cities (< 2)
>> This tells you that your data is not properly set up.
>> Study the manual page for v.net.salesman here:
>> https://grass.osgeo.org/grass-stable/manuals/v.net.salesman.html
>> There is a sample of v.net.salesman usage there which explains clearly
>> how to set things up.  Note creation of cities to visit and use of v.net
>> to create the network prior to running v.net.salesman.
>> Chris Hermansen · clhermansen "at" gmail "dot" com
>> C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250204/b6d8d67d/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250204/b6d8d67d/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250204/b6d8d67d/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250204/b6d8d67d/attachment-0005.png>
More information about the QGIS-User mailing list
