[Qgis-user] Least Cost Path
Abdou SENE / Geo - Tech - Dev
seneabdou460 at gmail.com
Wed Feb 5 14:53:39 PST 2025
According to My experience I can suggest you two things before you go:
1. Dissolve all the features of the network layer to Get one single feature
2. Run the snap points to line from SAGA to place the points on the
network.
Then run Shortest path algorithm.
Hope this will help.
Il Mer 5 Feb 2025, 22:42 chris hermansen via QGIS-User <
qgis-user at lists.osgeo.org> ha scritto:
> Krishna and list,
> On Wed, Feb 5, 2025 at 9:10 AM krishna Ayyala <ayyalakrishna at gmail.com>
> wrote:
>> Chris,
>> I am attaching the sample data. I have downloaded the road network online
>> which is an ESRI data. For this data, I am unable to run either shortest
>> path (layer to point) tool or v.net.salesman tool. It is giving me errors.
>> What corrections do I need to make to the network inorder to make this run?
>> Regards.
> I looked at your data very briefly. Here is a zoomed in portion near one
> of your points:
> [image: image.png]
> Looking at the line layer, it doesn't look to me to be a network graph,
> that is:
> 1. in a graph, all lines join at nodes - that is not the case in your
> data; I am not certain whether the various path algorithms require a
> pre-noded network or whether they will establish new nodes, so you may wish
> to investigate this issue further
> 1. the north-south road immediately to the west of the point is not
> noded at the double line highway
> 2. the same north-south road ends at the smaller road that sort of
> parallels the highway to the north, but that parallel road is not noded
> where the north-south road joins it
> 3. etc
> 2. you have some double-line roads, which are not wanted; I am
> reasonably confident you need to replace them with their "centreline" and
> then node that
> 3. there are duplicate lines, extra lines that don't end cleanly,
> don't end precisely on another line, etc, for example in this closeup of
> the west end of the highway:
> [image: image.png]
> I suggest you have some work to do to clean up the extra linework, and
> then you may need to node the clean linework.
> As to your points, at least the one shown above, it's not on top of a
> line. I suggest that, once you have a clean road system, you should at
> least ensure your points are on your roads, and you may need to create a
> node where the point touches the road line.
> You may find these references useful.
> https://changelog.qgis.org/en/qgis/lesson/data-acquisition-18/detail/63/?q=9.2
> https://docs.qgis.org/3.34/en/docs/user_manual/plugins/core_plugins/plugins_topology_checker.html
> https://gis.stackexchange.com/questions/tagged/v.clean
> https://docs.qgis.org/3.34/en/docs/training_manual/vector_analysis/network_analysis.html
> If your road network includes one-way streets you have more work to do.
> This reference may help:
> https://plugins.qgis.org/models/30/
> Good luck.
>> On Tue, Feb 4, 2025 at 2:47 PM chris hermansen <clhermansen at gmail.com>
>> wrote:
>>> Krishna and list,
>>> On Tue, Feb 4, 2025 at 12:43 PM krishna Ayyala <ayyalakrishna at gmail.com>
>>> wrote:
>>>> Chris,
>>>> Its nothing to do with the number of points. I got the same error when
>>>> I ran with 160 points.I also went to the study manual of v.net.salesman.
>>>> The network and points are as per their guidelines.
>>>> [image: image.png]
>>> These are different errors. You are supplying at least one incorrect
>>> input argument (see the <points> is not a valid parameter) and your input
>>> file "outputla.. etc..." is not found.
>>> I don't know what else to say, these messages seem pretty
>>> self-explanatory and there's no other info here to work with.
>>>> On Tue, Feb 4, 2025 at 1:08 PM chris hermansen <clhermansen at gmail.com>
>>>> wrote:
>>>>> Krishna and list,
>>>>> On Tue, Feb 4, 2025 at 11:49 AM krishna Ayyala <
>>>>> ayyalakrishna at gmail.com> wrote:
>>>>>> I also ran v.clean on the network. Then ran v.net.salesman on the
>>>>>> cleaned network. That did not help. Getting the same error message. Is
>>>>>> there a fix for this? I wish to run v.net.salesman without any errors.
>>>>>> On Tue, Feb 4, 2025 at 12:15 PM krishna Ayyala <
>>>>>>> Chris,
>>>>>>> Again thanks for your reply. I am not sure if my network is proper.
>>>>>>> I downloaded this from an online data source. How to fix it, if there are
>>>>>>> any errors? Are there any tools in qgis to fix this?
>>>>>>> Regards.
>>>>>>> On Tue, Feb 4, 2025 at 12:12 PM chris hermansen <
>>>>>>> clhermansen at gmail.com> wrote:
>>>>>>>> Krishna and list,
>>>>>>>> On Tue, Feb 4, 2025, 10:49 krishna Ayyala <ayyalakrishna at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> Chris,
>>>>>>>>> Alternatively, I ran v.net.salesman. Even that is giving following
>>>>>>>>> error.
>>>>>>>>> [image: image.png]
>>>>>>>>> [image: image.png]
>>>>> Look at the message - Number of cities: 0 / ERROR: Not enough cities
>>>>> (< 2)
>>>>> This tells you that your data is not properly set up.
>>>>> Study the manual page for v.net.salesman here:
>>>>> https://grass.osgeo.org/grass-stable/manuals/v.net.salesman.html
>>>>> There is a sample of v.net.salesman usage there which explains clearly
>>>>> how to set things up. Note creation of cities to visit and use of
>>>>> v.net to create the network prior to running v.net.salesman.
>>>>> Chris Hermansen · clhermansen "at" gmail "dot" com
>>>>> C'est ma façon de parler.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250205/744cf01e/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250205/744cf01e/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250205/744cf01e/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250205/744cf01e/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250205/744cf01e/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250205/744cf01e/attachment-0009.png>
More information about the QGIS-User
