[Qgis-user] QGIS Server setup <-- PostgreSQL/PostGIS
Gerald Kogler
geraldo at servus.at
Sun Feb 9 08:42:40 PST 2025
The parameters you indicate don't exist, but there does exist
QGIS_PROJECT_FILE, see documentation at
https://docs.qgis.org/3.34/en/docs/server_manual/config.html#server-env-variables
The best way to find possible connection problems or configuration
errors is to have a look at the QGIS Server logs.
Good luck
Gerald
On 8/2/25 22:56, Sebastián Meyer via QGIS-User wrote:
> Hi,
> I'm working on setting up a QGIS server which should retrieve projects
> and their layers from a PostgreSQL PostGIS enabled database, but I can't
> find (or I'm not understanding) how to do it.
> I've tried passing QGIS_PG_CONNECTION and QGIS_PROJECT_STORAGE variables
> through Apache without success (error codes 500 381)
> #My browser
> This XML file does not appear to have any style information associated
> with it. The document tree is shown below.
> <ServerException>Project file error. For OWS services: please provide a
> SERVICE and a MAP parameter pointing to a valid QGIS project file</
> ServerException>
> What am I missing?
> For storing projects I'm using 'qgis_metadata' schema with a
> 'qgis_projects' table. For projects' layers, I'm grouping them in
> different schemas.
> #Apache webserver config
> SetEnv QGIS_PG_CONNECTION "postgresql://user:pass@qgis.server:7000/
> proyectos_qgis"
> SetEnv QGIS_PROJECT_STORAGE "postgresql://user:pass@qgis.server:7000/
> proyectos_qgis?qgis_metadata.qgis_projects"
> I've tested database access.
> seb
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User
