[Qgis-user] QGIS Server setup <-- PostgreSQL/PostGIS
Sebastián Meyer
sebastian at indomitux.com
Tue Feb 11 14:52:40 PST 2025
Thanks a lot! Subject cleared!
I'll share my details, Apache config, tests that work and full error log.
Apache qgis.server:6080
PostgreSQL qgis.server:7000
DB structure: proyectos_qgis / qgis_metadata / qgis_projects (projects)
/ z_project1 / layer n
### Apache config (I left off logs variables only. Maybe some mandatory
variables I'm missing? No QGIS_AUTH_DB_DIR_PATH or PG_SERVICE_FILE...)
<VirtualHost *:6080>
ServerAdmin webmaster at qgis.server
ServerName qgis.server
DocumentRoot /var/www/html
# Longer timeout for WPS... default = 40
FcgidIOTimeout 120
FcgidInitialEnv LC_ALL "es_AR.UTF-8"
FcgidInitialEnv PYTHONIOENCODING UTF-8
FcgidInitialEnv LANG "es_AR.UTF-8"
SetEnv QGIS_PROJECT_FILE
"postgresql://user:pass@qgis.server:7000?sslmode=disable&dbname=proyectos_qgis&schema=qgis_metadata&project=z_project1"
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin/">
AllowOverride None
Options +ExecCGI -MultiViews -SymLinksIfOwnerMatch
Require all granted
</Directory>
<IfModule mod_fcgid.c>
FcgidMaxRequestLen 26214400
FcgidConnectTimeout 60
FcgidInitialEnv DISPLAY ":99"
</IfModule>
</VirtualHost>
### Tested
a- DB access successfully with
sudo -u www-data psql "dbname='proyectos_qgis' host='qgis.server'
user='user' password='pass' port='7000'"
b- Full project access from QGis Desktop via PostGIS connection to
z_project1
### Error log to request
http://qgis.server:6080/cgi-bin/qgis_mapserv.fcgi?MAP=z_project1&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&FORMAT=image/jpeg
18:51:07 INFO Server[5035]: QGIS Server Starting : 3.40.3-Bratislava
(2a274ab7754)
18:51:07 INFO Server[5035]: QGIS Server Settings:
<snip> LOT OF INFOs </snip>
18:51:07 WARNING Server[5035]: Invalid cache strategy, expecting
'filesystem', 'periodic' or 'off'. Using 'filesystem' as default.
18:51:07 INFO Server[5035]: Initializing 'filesystem' cache strategy
18:51:07 INFO Server[5035]: Server initialized
18:51:07 INFO ./src/server/qgsserverplugins.cpp[5035]: load library
/usr/lib/qgispython (3.40.3)
18:51:07 INFO ./src/server/qgsserverplugins.cpp[5035]: Python support
library loaded successfully.
18:51:08 INFO Server[5035]: No server python plugins are available
18:51:08 INFO Server[5035]: ******************** New request ***************
18:51:08 INFO Server[5035]: Request URL:
18:51:08 INFO Server[5035]: Environment:
18:51:08 INFO Server[5035]: ------------------------------------------------
18:51:08 INFO Server[5035]: SERVER_NAME: qgis.server
18:51:08 INFO Server[5035]: REQUEST_URI:
18:51:08 INFO Server[5035]: SCRIPT_NAME: /cgi-bin/qgis_mapserv.fcgi
18:51:08 INFO Server[5035]: REMOTE_ADDR: 172.30.64.19
18:51:08 INFO Server[5035]: SERVER_PORT: 6080
18:51:08 INFO Server[5035]: QUERY_STRING:
18:51:08 INFO Server[5035]: REQUEST_METHOD: GET
18:51:08 INFO Server[5035]: QGIS_PROJECT_FILE:
18:51:08 INFO Server[5035]: SERVER_PROTOCOL: HTTP/1.1
Headers:
"Accept" :
"text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"
"Host" : "qgis.server:6080"
"User-Agent" : "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36
(KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36"
18:51:08 INFO Server[5035]: FORMAT:image/jpeg
18:51:08 INFO Server[5035]: MAP:z_project1
18:51:08 INFO Server[5035]: REQUEST:GetMap
18:51:08 INFO Server[5035]: SERVICE:WMS
18:51:08 INFO Server[5035]: VERSION:1.3.0
18:51:08 CRITICAL Server[5035]: Error when loading project file
'z_project1': Unable to open z_project1
18:51:08 WARNING Server[5035]: <?xml version="1.0" encoding="UTF-8"?>
<ServerException>Project file error. For OWS services: please provide a
SERVICE and a MAP parameter pointing to a valid QGIS project
file</ServerException>
18:51:08 INFO Server[5035]: Request finished in 2 ms
TIA,
seb
More information about the QGIS-User
