[Qgis-user] Available sizes for QgsLayoutItemPage
Garth Fletcher
garth at jacqcad.com
Tue Feb 25 21:05:21 PST 2025
Aren't you confusing the physical dimensions for PDF output with display
size in pixels?
For example, "ANSI B" refers to an intended document size 8.5 x 11 inches.
The output resolution for Image or PDF can be set in DPI in
Project > Import/Export > Export Map to... PDF or Image
On Wed, 26 Feb 2025 at 11:57, afernandez wrote:
> I was looking for the one with the highest aspect ratio, which is 1080 x 1920 px and seems to be working well for my purposes. Thank you for the help.
Garth Fletcher
More information about the QGIS-User
