[Qgis-user] HELP unable to sort multiple attribute values within a field
John Bryant
johnwbryant at gmail.com
Tue Feb 25 21:43:19 PST 2025
Hi Kelly, one method to try is to use a "Rule-based" renderer with a
rule for each species, something like:
array_contains(string_to_array("type", '; '), 'Hyptis')
This expression pattern should also work (but you might get false positives
where one species name is a partial match for another):
"type" like '%Alligator Weed%'
Each category would include all the features that match the expression, so
some features would appear in more than one category.
[image: image.png]
Cheers
John
On Wed, 26 Feb 2025 at 11:33, Kelly Hart via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hello I am attempting to map different weed varieties found in different
> areas (attribute table attached). I need to sort by All Weeds field but
> some of the entries have more than one attribute value. I need to be able
> to map them separately – ie all sicklepod together, all caltrop together
> and so on. Is there a way to sort this to occur? I’ve tried a few different
> ways though expression builder but no luck so far.
> I am using QGIS version 3.34.11-Prizren.
> Appreciate any advice. Cheers Kel
> *Kelly*********
> *Hart*
> Women's Ranger Coordinator
> * Mimal Land Management*
> *M: *
> 0476 641 577 <0476%20641%20577>
> *E: *
> kelly.hart at mimal.org.au
> *W: *
> mimal.org.au
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250226/45fa8cf0/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250226/45fa8cf0/attachment-0001.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250226/45fa8cf0/attachment-0001.png>
More information about the QGIS-User
