[Qgis-user] Test builds for Linux with Qt 6?
Tobias Schula geospatial at schula.org
Thu Feb 27 13:42:16 PST 2025
Hi all,
I wanted to try out the new CMYK capabilities of QGIS 3.40 as laid out here:
> https://oslandia.com/en/2024/10/02/nouveau-dans-qgis-3-40-le-support-cmjn/
I wanted to try it with real data, as I'm about to send off a map for printing.
For that particular project, it doesn't matter, as the printer will convert
RGB to CMYK by themselves. The introduced fuzziness of thin lines and small
text by the automatic conversion are acceptable, as these are field maps that
will be covered with a waterproof, slightly grainy foil ("Mipofolie", great
product!).
However, I only saw a test build for Windows in this thread:
> https://github.com/qgis/QGIS-Enhancement-Proposals/issues/
283#issuecomment-2545776059
Are there also Qt 6 test builds available for Linux? Otherwise I will try to
build it according to the instructions here:
> https://github.com/qgis/QGIS/blob/master/INSTALL.md
Will a build with vcpkg use the version of Qt on my computer (6.8), or will it
pull a different version? I have never used vcpkg before, so how it works is
new for me.
Regards
Toby
Tobias A Schula
Forestry Expert
More information about the QGIS-User mailing list
