[Qgis-user] Open ESRI Geodatabase file in QGIS
Richard Greenwood richard.greenwood at gmail.com
Fri Jan 10 09:37:36 PST 2025
It would be really helpful if you provided details as to what you tried and
what failed. Did you go to:
    Data Source Manager > Vector > Directory
        Type:     OpenFileDGB
        Vector Dataset(s): <select a directory with a .gdb extension>
And if you followed those steps, what error did you get?
On Fri, Jan 10, 2025 at 2:49 AM Mangla Katyayani via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hi all,
> I am using the QGIS 3.40 version. I want to open a geodatabase file in
> QGIS but I am unable to do it using the OpenFileGDB driver. Need
> suggestions on possible solutions.
> Regards,
> Mangla
> Disclaimer: This email may be confidential. Please don't share without
> consent. Inform the sender if you got it by mistake.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Richard W. Greenwood
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250110/52a2582b/attachment.htm>
More information about the QGIS-User mailing list
