[Qgis-user] Geospatial PDF Not Measuring Distance Properly
g_lee at DCSdigital.ca g_lee at DCSdigital.ca
Mon Jan 20 14:10:45 PST 2025
Hi Andrea:
I have done some more experimentation.
I have outputted a geospatial PDF directly from the main QGIS window.  That’s seems to produce an accurate geospatial PDF in Adobe Acrobat Reader.
However when I export the geospatial PDF using a layout from the QGIS layout manager, that's where the problem with the scaling comes up.
Grayson
____
Grayson Lee
TC Advanced sRPAS/FAA Part 107 Pilot | BVLOS & Large RPAS Flight Operations | TC Flight Reviewer
Digital Content Solutions Inc.
https://www.DCSdigital.ca/
416.301.2750
-----Original Message-----
From: Andrea Giudiceandrea <andreaerdna at libero.it>
Sent: January 20, 2025 4:08 PM
To: g_lee at DCSdigital.ca; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Geospatial PDF Not Measuring Distance Properly
Il 20/01/2025 20:40, g_lee at DCSdigital.ca ha scritto:
> How do I tell the Measure Tool in Adobe Acrobat Reader is set to measure?
I was referring to the QGIS's Measure Tool.
In any case, since the map's CRS is a UTM projection, there shouldn't be a big difference between the Ellipsoidal and Cartesian measurements in QGIS.
Andrea
More information about the QGIS-User mailing list
