[Qgis-user] Georeferencing Problem in QGIS-Version 3.34.12-Prizren
Simon Dietmann
dietmann at pgnu.de
Fri Jan 24 07:45:32 PST 2025
To me it looks like you maybe choose the wrong transformation type - did you try to run the georeferncing with different types?
Cheers
SImon
-----Ursprüngliche Nachricht-----
Von: QGIS-User <qgis-user-bounces at lists.osgeo.org> Im Auftrag von Greg Troxel via QGIS-User
Gesendet: Freitag, 24. Januar 2025 16:41
An: Belal Elsharkawy via QGIS-User <qgis-user at lists.osgeo.org>
Betreff: Re: [Qgis-user] Georeferencing Problem in QGIS-Version 3.34.12-Prizren
Belal Elsharkawy via QGIS-User <qgis-user at lists.osgeo.org> writes:
> if anyone has an idea or can help, I have a problem with georeferencing any 2D plan since a long time and have tried almost everything possible.
> After importing the georeferencing wanted plan in the Georeferencing
> window in QGIS and choosing 3 points and their representatives in the
> main window plan, then going to the settings in the Georeferencing
> window to check the coordinate system and make sure that it’s the same
> as the one used in the main QGIS window as well as the Location where
> it will be saved.
> I always get a very big differences in the dx (Pixel) as well as the dy (Pixel) which they should be zero or near to zero (see the screenshot attached) and it doesn’t work.
> While other colleagues doing literally the same as I do, and it works for them.
I wonder if you somehow have an option checked not to allow rotation.
I would suggest putting in more points, at least 5 maybe even 10, and then look at patterns in the residuals.
What CRS is the project in? If it were in a geographic CRS instead of a projected (and conformal) CRS, I could see that causing problems.
Personally I tend to use a UTM zone of my national datum, or a lambert conformal conic ("state plane"). I would expect you have some similar CRS which fits local norms, perhaps UTM on ETRS.
QGIS-User mailing list
QGIS-User at lists.osgeo.org
List info: https://atpscan.global.hornetsecurity.com?d=s6vkDEbTWLpR_d-rdDtmjRDGi5OjeDSy9Td_mNttT0Y&f=cNDPJSviNyPOrwYK5ewHPDFh-g3_XMsSJtmRZRPmFxc&i=&k=HX5R&m=R9uTI0DzoBWMnhMnE-TbX-iFNUCkPFLvpnwqxRJCUxfXMXVVJ1NQPjJI75vlxOzfnkOQF3hdQGBpOsUK84XDPJQ7XQ98kEPBBvh0SVRKd_igKI8ue7drsn7k868cXFAe&n=UMvSYzxrX4cK57mT8EoykUo309COawyo9Q9rhSvT_2eRLbLd8MSFAvQdlEq_-vIp&r=50aqMSwLA9J75hwvlFJ5363XfHPS2Putx0SV2U67Tzs1fVY0xMKt_lITDGsOll9r&s=1e05ea7cf973e952f27a2952b92d549ab35fe8300022c856344cfa510d9f83a2&u=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user
Unsubscribe: https://atpscan.global.hornetsecurity.com?d=_75Fpceumn0vDn8VQm_NwYRUlWFVrPoWJ9YXjg9zWq0&f=7MvobO8sO5rV9ARBuEk5J4pNxswpoojr1dyYc08_1ic&i=&k=Gcln&m=UGdu3-XkerRHqpqe2cBsg09nbxSDj3ApMLhH03-3_HQD4-goB12jtcl7bzZPj80Hw_CdR8lbN4vGIqzky2kqA8sqtmbg2z6Ut6tg5Myn8IXf2x6HAYOKdmEGUayln-Hq&n=uoxjfq00fyXwZOv9cxQSkHUFccXFweWrCFyz5Vlu0GcCFEeM95Rbt7FrFEcx3dp8&r=lZV5ahLo4xo83Kjo-as93Uz2LRugkNwU-z81mbl8O0_mEo5OBjqpLGFBf4EQ0bKe&s=6933877390ed62c6ad54bdff2ffef88a3f61cb269f06823aac3454d02b8f2f90&u=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user
More information about the QGIS-User
