[Qgis-user] Self Intersections: Issues with Polygon Features
Nigel Berjak - General nigel at s3.co.za
Thu Jul 3 08:20:06 PDT 2025
Hi Werner
An old trick is to buffer using 0 units, which usually resolves
self-intersections.
Cheers.
Regards,
Nigel Berjak
Please consider the environment before printing this email.
On 2025-07-03 16:11, Isenmann, Werner (RPF) via QGIS-User wrote:
> Hi,
> some colleagues have problems with shapefiles (really...) that contain
> polygons with self-intersections. The Vector Overlay - Clip tool, for
> example, cannot be executed because the algorithm does not run due to
> the self-intersection. Before executing the tool, the parameter
> 'Invalid feature filtering' can be set to 'Skip (Ignore) Features with
> Invalid Geometies'. The faulty polygons are then skipped, which is not
> desirable, however.
> QGIS offers various options for repairing self-intersections, for
> example:
> 1) Vector - Check Geometries plugin: however, this sometimes has very
> long runtimes which might not be acceptable.
> 2) Vector Geometry - Check Validity
> a - Method QGIS: takes a very long time, or does not run through
> b - Method GEOS: works correctly and quickly. However, only the first
> error is ever found. This is not convenient for files with many errors.
> Does anyone know a good solution for repairing (many)
> self-intersections with high performance in QGIS?
> Many thanks in advance,
> Werner
> Werner Isenmann
> Regierungspräsidium Freiburg
> Referat 91 - Geowissenschaftliches Landesservicezentrum
> Albertstraße 5
> D-79104 Freiburg i. Br.
> Phone: (+49) 761 208-3008
> E-Mail: Werner.Isenmann at rpf.bwl.de
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250703/49d08179/attachment.htm>
More information about the QGIS-User mailing list
