[Qgis-user] Qgis/Postgis : Multi Union (25 polygonal layers)
chris hermansen
clhermansen at gmail.com
Mon Jul 7 10:21:32 PDT 2025
Laurent and list;
On Mon, Jul 7, 2025 at 2:44 AM celati Laurent via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Dear all,
> I'm working with QGIS and PostGIS. As input, I have 25 polygonal layers
> covering a large area (multicities area). One of these data is a very large
> dataset (1 million objects). The other 24 are much smaller (a maximum of a
> hundred objects).
> For information, I should point out that some of these polygonal datasets
> are in "multi-part features" mode and others in "single-part features"
> mode. I imagine this may ultimately have a slight impact on the
> method/result. These 25 polygonal .shp files have highly variable,
> non-homogeneous/non-harmonized data structures. Each layer has a "data_id"
> field that allows to define/link/reference, for each feature, its
> membership in the layer. For example, all values in the "data_id" field for
> the first layer have a value of '1'. For the second layer, the field values
> are '2', etc.
> My goal would be to be able to apply/adapt the existing QGIS geoprocessing
> tool called "Multiple Union":
> https://docs.qgis.org/3.40/en/docs/user_manual/processing_algs/qgis/vectoroverlay.html#union-multiple
> Below a screenshot from the QGIS documentation :
> [image: image.png]
> My goal would be to have an output file:
> - Which would be the result of the union/overlay of the 25 input
> data. To use the terms of the QGIS documentation, the processing should
> check for overlaps between features within the 25 layers and create
> separate features for the overlapping and non-overlapping parts. This
> "multiple union" geoprocessing seems interesting for my goal where there is
> no overlap (a, NULL; b, NULL; c, NULL).
> - For areas where there is an overlap, the QGIS union geoprocessing
> creates as many identical overlapping features as there are features
> participating in this overlap. This doesn't bother me. But since,
> ultimately, I'd like a field in the result/output file to allow, for each
> feature, to retrieve the list of input layers that participate/contribute
> to this result feature (in order to retrieve the origin/source of the
> data). I was wondering/thinking it might be better if only one feature was
> created per overlapping area?
> - I'd like a field in the result file to allow, for each feature, to
> retrieve the list of input layers that participate/contribute to this
> result feature. In order to retrieve the origin/source of the data.
> - Ideally, a field that allows you to retrieve the number (COUNT) of
> layers that contribute to this feature (at least 1 layer, at most 25
> layers).
> - Regarding the non-geometric attributes/fields, I would like to be
> able to specify the selection/define the list of fields I ultimately want
> to keep. I don't want to keep all of the fields, but rather just some of
> the fields for each of the 25 input layers.
> I imagine it's recommended to do this processing in PostGIS rather than
> QGIS? I can, if necessary, import my 25 SHP files into a PostGIS database.
> I also imagine it's important to keep in mind that the "multi-part
> features" / "single-part pieces/features" mode of the input layers can
> affect the result. If I'm using a PostGIS query, I was thinking it might be
> helpful to force all features to be in single-part mode (using the PostGIS
> 'st_dump' function?).
If this were my task, I would surely do it all in PostGIS.
Back in my forestry days, we had a very similar problem to solve - in a
large area (hundreds of thousands to millions of hectares), a very detailed
forest vegetation layer and 10+ layers of policy, administration and
operational concerns, all to be combined via a union process to generate a
"resultant" that could be fed into a long-term model to calculate
sustainable flows of forest products, silvicultural treatments and so on.
Some of the general principles I recall are:
- the need to buffer line and point concerns into reasonable polygons (not
overly dense number of vertices, for example)
- the need to have single part polygons
- the need to simplify unnecessarily complicated polygon shapes (again,
reduce unnecessarily dense vertices)
- the need to normalize all layers to reduce the cost of writing the
results of the unions back to the database (for example, polygon
non-spatial attributes on separate table linked to the spatial component)
- the need to have a spatial indexing strategy and to review EXPLAIN costs
to check that the strategy works
- the need to investigate the performance requirements of repeated
operations that simultaneously read and write large tables, possibly
requiring PostgreSQL configuration tuning
- the usual best approach being
- union all the smaller tables together first,
- then union that product with the detailed forest vegetation layer,
- then consider pulling the required subset of attributes onto the
resultant polygon records; or alternatively create a view
Some observations about your goals:
- I suppose you can create this resultant as overlapping polygons or
alternatively as polygons "cut into" each other (what ESRI used as the
original definition of union)
- I have always worked with the "cut into" version, which results in a
final table with the cut-up geometry for each overlap area and all the IDs
of the constituent pieces as individual attributes
- in that case your COUNT is just the number of non-null ID columns for
each record
- with a normalized set of input tables the ID column for each input layer
allows you to retrieve the information for the input layer
- with a normalized set of input tables, you need to specify the non-ID
fields that you keep, either by appending those fields to the resultant
table or creating a view or just doing table joins
I'm going to stop here for now.
Chris Hermansen · clhermansen "at" gmail "dot" com
C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250707/a10d814a/attachment.htm>
More information about the QGIS-User
