[Qgis-user] Qgis server postgis layers not valid (but desktop works on same machine)
Amedeo Fadini
amefad at gmail.com
Mon Jul 7 12:54:40 PDT 2025
Hi everybody,
I'm upgrading a project based on QGIS server and moved all stuff to new
server with Ubuntu 24, QGIS 3.40 LTR postgresql 16.
Webserver is nginx, QGIS server is configured on spawn-fcgi with single
socket follwing the qgis manual
https://docs.qgis.org/3.40/en/docs/server_manual/getting_started.html#spawn-fcgi
The project use two layers from postgis, the connection is configured with
pg service
Connecting on ssh with x.forwarding the project loads without any error and
works fine
Calling the qgis server getcapabilities or get projectsettings it raise the
error
<ServerException>Layer(s) not valid</ServerException>
Setting QGIS_SERVER_IGNORE_BAD_LAYERS=true getcapabilities works but
postgis layer are not published or not showed in Getmap request.
Any clue? Where can I find more detailed erro log?
even the demo project world.qgs gives balnk image in getmap request. Am I
misisng a local Xserver or gui configuration?
Below is my nginx conf and systemd/system/qgis-server.service
Thank you
Amedeo Fadini
server {
listen 80;
server_name <my server name>;
location /qgis/ {
include fastcgi_params;
fastcgi_param SCRIPT_FILENAME /usr/lib/cgi-bin/qgis_mapserv.fcgi;
#fastcgi_param QGIS_DEBUG 1;
fastcgi_param QGIS_SERVER_LOG_STDERR 1;
#fastcgi_param QGIS_SERVER_LOG_LEVEL 0;
fastcgi_param QGIS_SERVER_LOG_LEVEL 2;
#fastcgi_param PGSERVICEFILE /home/ubuntu/.pg_service.conf;
#fastcgi_param QGIS_PROJECT_FILE
/home/ubuntu/fiduciali_qgis/fiduciali.qgs;
fastcgi_pass unix:/var/run/qgisserver.socket;
[Unit]
Description=QGIS server
After=network.target
[Service]
;; set env var as needed
;Environment="LANG=en_EN.UTF-8"
;Environment="QGIS_SERVER_PARALLEL_RENDERING=1"
;Environment="QGIS_SERVER_MAX_THREADS=12"
Environment="QGIS_SERVER_LOG_LEVEL=0"
Environment="QGIS_SERVER_LOG_STDERR=1"
Environment="PGSERVICEFILE=/home/ubuntu/.pg_service.conf"
;Environment="QGIS_PROJECT_FILE=/var/www/qgis_projects/world.qgs"
Environment="QGIS_PROJECT_FILE=/var/www/qgis_projects/fiduciali.qgs"
Environment="QGIS_SERVER_IGNORE_BAD_LAYERS=true"
;; or use a file:
;EnvironmentFile=/etc/qgis-server-env
ExecStart=spawn-fcgi -s /var/run/qgisserver.socket -U www-data -G www-data
-n /usr/lib/cgi-bin>
[Install]
WantedBy=multi-user.target
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250707/0cfd9075/attachment.htm>
More information about the QGIS-User
