[Qgis-user] Model desinger / enum input question
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Thu Jun 12 09:15:20 PDT 2025
Okay, no answers for the question.
For future reference (if others have the same problem and find this
posting) :
You can use an array constructor together with the array_get function
i.e., if you have an Enum processing input  "animals" with values like
"Gorilla","Snake" and "Elephant", you can get the enum textual value by
using this construct:
*array_get(array('Gorilla','Snake','Elephant'), at animals)*
It's not pretty - but it much shorter than writing a potentially
humongous CASE..WHEN construct.
An even better method would be to use a (hypothetical)  function that
returns a list of enumeration texts based on the name of the input, like
*array_get(enum_texts('animals'), at animals) *or - even better
-***enum_text('animals',**@animals**)*
However, i haven't found these hypothetical functions.
Med venlig hilsen / Best regards
Bo Victor Thomsen
On 10/06/2025 12.35, Bo Victor Thomsen wrote:
> Hi list -
> I'm designing a processing model, where i use a "Enum" input. When
> accessing this variable in a "Calculate Expression" algorithm in the
> model, the result will be an ordinal value - not a text - from the enum.
> Example:
> I have an enum named "animal" defined with 3 animal names like
> "Gorilla","Snake","Elephant". If the user choose "Snake" the variable
> @animal contains the number "1" instead of "Snake". How do I get the
> textual representation of the enum instead of the ordinal ?
> I'm aware I can use a CASE... WHEN in the expression. But it will be
> cumbersome for enums with many values.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250612/fd382994/attachment.htm>
More information about the QGIS-User mailing list
