[Qgis-user] Plugin "Terminus" and "BoundaryDelineation": error for the launching
    celati Laurent
    laurent.celati at gmail.com
    Mon Jun 30 03:51:26 PDT 2025
Hello,
Regarding 2 plugins : "Terminus", and "boundary-delineation", I'm facing an
error message when i try to enable the plugins via the qgis plugin manager.
 I work with
Version of Python : 3.12.7 (main, Oct 25 2024, 11:18:09) [MSC v.1938 64 bit
(AMD64)]
Version of QGIS : 3.34.13-Prizren Prizren, 222b5995
Please find below the two distincts  errror messages :
For Termnus :
> Impossible de charger l'extension 'terminus_processing' provoque une
> erreur lors de l'appel à sa méthode classFactory() ModuleNotFoundError: No
> module named 'skimage' Traceback (most recent call last): File
> "C:\PROGRA~1/QGIS33~1.13/apps/qgis-ltr/./python\qgis\utils.py", line 423,
> in _startPlugin plugins[packageName] = package.classFactory(iface)
> ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File
> "C:\Users/XXXXX/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\terminus_processing\__init__.py",
> line 38, in classFactory from .terminus_processing import TerminusPlugin
> File "C:\PROGRA~1/QGIS33~1.13/apps/qgis-ltr/./python\qgis\utils.py", line
> 892, in _import mod = _builtin_import(name, globals, locals, fromlist,
> level) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File
> "C:\Users/XXXXX/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\terminus_processing\terminus_processing.py",
> line 42, in from .terminus_processing_provider import TerminusProvider File
> "C:\PROGRA~1/QGIS33~1.13/apps/qgis-ltr/./python\qgis\utils.py", line 892,
> in _import mod = _builtin_import(name, globals, locals, fromlist, level)
> "C:\Users/XXXXX/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\terminus_processing\terminus_processing_provider.py",
> line 39, in from .image_segmentation_processing_felzenszwalb import
> Imagesegmentationfelzenszwalb File
> "C:\Users/XXXXX/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\terminus_processing\image_segmentation_processing_felzenszwalb.py",
> line 41, in from skimage import io File
> ModuleNotFoundError: No module named 'skimage'
For "BoundaryDelineation" :
Impossible de charger l'extension 'BoundaryDelineation' provoque une erreur
lors de l'appel à sa méthode classFactory() AttributeError: partially
initialized module 'networkx' has no attribute 'utils' (most likely due to
a circular import) Traceback (most recent call last):
"C:\Users/XXXXX/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\BoundaryDelineation/lib\networkx\algorithms\tree\recognition.py",
line 88, in @nx.utils.not_implemented_for('undirected') ^^^^^^^^
AttributeError: partially initialized module 'networkx' has no attribute
'utils' (most likely due to a circular import)
Thanks so much for your help.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250630/60805871/attachment.htm>
More information about the QGIS-User
