[Qgis-user] questions for qgis server deployment
sebastian at indomitux.com sebastian at indomitux.com
Sat Mar 1 05:52:09 PST 2025
Hi everyone,
I am in the process of configuring a QGIS server, but I’m encountering
some confusion around certain variables and concepts in the
documentation.
What I aim to deploy is a server with a PostGIS backend, with different
schemas for various projects, and MapStore for queries and dashboards.
Using the `qgis.demo.conf` from the documentation, I have the following
configuration:
   # Default QGIS project
   SetEnv QGIS_PROJECT_FILE /home/qgis/projects/world.qgs
   # QGIS_AUTH_DB_DIR_PATH must point to a directory writable by the
Server's FCGI process user
   FcgidInitialEnv QGIS_AUTH_DB_DIR_PATH "/home/qgis/qgisserverdb/"
   FcgidInitialEnv QGIS_AUTH_PASSWORD_FILE
"/home/qgis/qgisserverdb/qgis-auth.db"
   # Set PostgreSQL access via the pg_service file
   SetEnv PGSERVICEFILE /home/qgis/.pg_service.conf
   FcgidInitialEnv PGPASSFILE "/home/qgis/.pgpass"
Here are my questions:
a) Is it possible to use a QGIS project file, like in the example above,
while also using PostGIS as a backend service?
b) The variables `QGIS_AUTH_DB_DIR_PATH` and `QGIS_AUTH_PASSWORD_FILE`
are not documented in the "6.2. Environment Variables" section. Could
you clarify what these are used for?
c) As far as I know, `PGSERVICEFILE` doesn’t include a variable for
specifying a schema other than `public`. So, is the only option to
define the schema in the connection string in the `QGIS_PROJECT_FILE`
variable?
d) Once I have everything configured, should pointing my browser to
`qgis_mapserv.fcgi` bring up a basic catalog with the projects stored in
the database?
Thanks in advance, wish you a nice weekend!
seb
More information about the QGIS-User mailing list
