[Qgis-user] question about merging .gml files
archy haddockk yarchadik1 at gmail.com
Mon Mar 10 11:06:50 PDT 2025
 Hello,
Could someone help me with this problem?
I have these error messages when I try to merge gml files. (a map at .gml
format)
LABEL field in layer A992_BORGHETTO DI VARA_map — CadastralZoning has
different data type than the destination layer (Integer instead of String).
LABEL field will be converted to string type.  etc...
Sometimes "integer instead of integer" (???)
... LABEL field in layer B839_CARRODANO_map — CadastralZoning has different
data type than the destination layer (Integer instead of Integer). LABEL
Final error message:
Feature could not be written to
Merged_6e799ff6_aa23_4142_ae26_d59580c206a8: Could not store attribute
"lowerCorner": String of length 19 exceeds maximum field length (18)
Could not write feature into OUTPUT
Execution failed after 0.06 seconds
Please can you tell me how I can fix these problems, for I found no
solution nowhere and noone could help me so far.
Thank youn in advance.
Sincerely
Jenny HADD
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250310/44f15cdd/attachment.htm>
More information about the QGIS-User mailing list
