[Qgis-user] Ubuntu LTS 22.04 installation problem
Alvaro Manrique
alvaro.manrique6903 at gmail.com
Wed Mar 12 17:51:11 PDT 2025
Hello everyone,
I'm having issues installing the latest QGIS version:
alvaromanrique at alvaromanrique-Crosshair-17-C12VF:~$ sudo apt upgrade
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Calculating upgrade... Done
Get more security updates through Ubuntu Pro with 'esm-apps' enabled:
python3-jupyter-core libde265-dev libheif1 imagemagick libjs-jquery-ui
libopenexr-dev libavdevice58 ffmpeg libopenexr25 python3-scipy
libpostproc55
libmagickcore-6.q16-6-extra libswscale-dev libavcodec58
libmagickwand-6.q16-6 libavutil56 imagemagick-6.q16 libswscale5
libheif-dev
libmagickcore-6.q16-6 libavutil-dev libgsl27 libswresample3
imagemagick-6-common libavformat58 libgslcblas0 libavformat-dev
libavcodec-dev libde265-0 libpmix2 libswresample-dev libavfilter7
Learn more about Ubuntu Pro at https://ubuntu.com/pro
The following packages have been kept back:
grass-core
0 to upgrade, 0 to newly install, 0 to remove and 1 not to upgrade.
4 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up qgis-providers (1:3.40.3+36jammy) ...
/usr/lib/qgis/crssync: error while loading shared libraries:
libpdal_base.so.13: cannot open shared object file: No such file or
directory
dpkg: error processing package qgis-providers (--configure):
installed qgis-providers package post-installation script subprocess
returned error exit status 127
dpkg: dependency problems prevent configuration of qgis:
qgis depends on qgis-providers (= 1:3.40.3+36jammy); however:
Package qgis-providers is not configured yet.
dpkg: error processing package qgis (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of qgis-plugin-grass:
qgis-plugin-grass depends on qgis (= 1:3.40.3+36jammy); however:
Package qgis is not configured yet.
dpkg: error processing package qgis-plugin-grass (--configure):
dpkg: dependency problems prevent configuration of python3-qgis:
python3-qgis depends on qgis-providers (= 1:3.40.3+36jammy); however:
dpkg: error processing package python3-qgis (--configureNo apport report
written because the error message indicates it's a follow-up error from a
previous failure.
No apport report written because the error mess
age indicates it's a follow-up error from a previous failure.
No apport
report written because MaxReports has already been reached
Errors were encountered while processing:
qgis-providers
qgis
qgis-plugin-grass
python3-qgis
E: Sub-process /usr/bin/dpkg returned an error code (1)
Can you help me with this?
Best wishes.
Alvaro MANRIQUE Jiménez
CIP: 01165409
DNI: 71252717
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250312/4536ccff/attachment.htm>
More information about the QGIS-User
