[Qgis-user] Different values for $area and 'Add Geometry Attributes'
Andrea Giudiceandrea
andreaerdna at libero.it
Fri Mar 14 03:20:52 PDT 2025
Hi Jochen,
I forgot to mention that the "Add geometry attributes" processing
algorithm can calculate length, perimeter and area values either
planimetric in the layer's CRS (as the "length", "perimeter", and "area"
functions) or planimetric in the project's CRS or ellipsoidal (as the
"$length", "$perimeter" and "$area" functions) depending on the
"Calculate using" (CALC_METHOD) algorithm's parameter setting.
I suppose you have set the "Calculate using" (CALC_METHOD) algorithm's
parameter to "0 — Layer CRS" (which is the default value) or "1 —
Project CRS".
Regards.
Andrea
Il 13/03/2025 19:47, Andrea Giudiceandrea ha scritto:
> Hi Jochen,
> as described in the user manual, the "Add geometry attributes"
> processing algorithm [1] "generates a new vector layer ... containing
> geometric measurements based on a selected CRS.", i.e. it measures
> Cartesian planimetric length and area on the CRS's cartographic plane.
More information about the QGIS-User
