[Qgis-user] question
Sylvain Ard sylvain.ard at gmail.com
Sat Mar 15 03:35:02 PDT 2025
What’s the difference between the two then ? And what is the fastest please
Le ven. 14 mars 2025, 22:35, Brent Wood <Brent.Wood at niwa.co.nz> a écrit :
> Postgis generated hexagons are NOT H3 hexagons - unless you very carefully
> generate them to fit.
> Use the Postgres h3 extension for h3 hexagon support:
> https://blog.rustprooflabs.com/2022/04/postgis-h3-intro
> Brent Wood
> Principal Technician, Fisheries
> NIWA
> DDI:  +64 (4) 3860529
> *From:* Sylvain Ard <sylvain.ard at gmail.com>
> *Sent:* Saturday, March 15, 2025 08:49
> *To:* Brent Wood <Brent.Wood at niwa.co.nz>
> *Cc:* qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
> *Subject:* Re: [Qgis-user] question
> yes but H3 can't simplify the job ?
> Sylvain Ard
> 0549507724
> 0778380991
> https://www.sylvain-ard.fr <http://sylvain-ard.fr/>
> Entreprise individuelle SIRET : 80079243400022
> Appt 26 Bât A Résidence Le Patio
> 83 rue de la Bugellerie
> 86000 Poitiers
> Le ven. 14 mars 2025 à 20:48, Brent Wood <Brent.Wood at niwa.co.nz> a écrit :
> Hi,
> Off the top of my head...
> Postgis can easily cope with millions of records. Given the points are
> there, use that to create the hexagons as required - this can be done using
> https://postgis.net/docs/ST_HexagonGrid.html
> If you set up your QGIS project with preset zoom levels, and create a set
> of appropriately sized hexagons for each zoom level, then populate a column
> with the number of points it contains.
> There will be some devilish details - as you zoom in, the polygon's real
> area will get smaller, so will contain less points. A fixed symbology will
> therefore change the colour range with the scale.
> Calculating a normalised value, perhaps something like instead of the no
> of points, you calculate a normalised value - the hex at each scale with
> the most points gets 100, the rest get a value based on the no of
> points/the max for that scale, so all polygon datasets will have colours
> set to values between 0 and 100. All doable with SQL.
> Do all the data stuff in Postgis, then just plot in QGIS.
> There are various ways to set QGIS up for this, but one reasonably
> straightforward way that should work is having a separate hexagon layer for
> each scale, with a scale limit on displaying it so that all map scales are
> represented by one of the hexagon layers, with the fixed zoom
> levels/scales, set the same symbology for each layer, then  group them into
> a single group.
> Something to consider anyway...
> Cheers
> Brent Wood
> NIWA
> *From:* QGIS-User <qgis-user-bounces at lists.osgeo.org> on behalf of
> Sylvain Ard via QGIS-User <qgis-user at lists.osgeo.org>
> *Sent:* Friday, March 14, 2025 23:35
> *To:* qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
> *Subject:* [Qgis-user] question
> Hello,
> I'd like a map with hexagons that are darker the more points there are
> underneath. My points are in a PostgreSQL table. If there are no points,
> there should be no hexagon. The hexagons have a constant size on the
> screen, so they have to be recalculated each time the map is zoomed in. I
> want a truly optimized solution because I have millions of points. So,
> perhaps I could use QGIS-server.
> Please suggest a solution for both the server and client side.
> Best regards
> PS : my map must be like GBIF maps
> Sylvain Ard
> 0549507724
> 0778380991
> 86000 Poitiers
> <https://www.niwa.co.nz/>
> Brent Wood
> Principal Technician - GIS and Spatial Data Management
> Programme Leader - Environmental Information Delivery
> +64-4-386-0529
> National Institute of Water & Atmospheric Research Ltd (NIWA)
> 301 Evans Bay Parade Hataitai Wellington New Zealand
> *Connect with NIWA:* niwa.co.nz <https://www.niwa.co.nz/> Facebook
> <https://www.facebook.com/nzniwa> LinkedIn
> <https://www.linkedin.com/company/niwa> Twitter
> <https://twitter.com/niwa_nz> Instagram
> <https://www.instagram.com/niwa_science> YouTube
> <https://www.youtube.com/channel/UCJ-j3MLMg1H59Ak2UaNLL3A> To ensure
> compliance with legal requirements and to maintain cyber security
> standards, NIWA's IT systems are subject to ongoing monitoring, activity
> logging and auditing. This monitoring and auditing service may be provided
> by third parties. Such third parties can access information transmitted to,
> processed by and stored on NIWA's IT systems.
> Note: This email is intended solely for the use of the addressee and may
> contain information that is confidential or subject to legal professional
> privilege. If you receive this email in error please immediately notify the
> sender and delete the email.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250315/6118c20b/attachment.htm>
More information about the QGIS-User mailing list
