[Qgis-user] Different values for $area and 'Add Geometry Attributes'
Nigel Berjak - General
nigel at s3.co.za
Sat Mar 15 08:08:30 PDT 2025
Hi Jochen
The alternative to $area is to use area($geometry), which then applies
the area based upon the CRS of the layer and the specific geometry,
instead of the project. Perhaps this is what you are needing to apply.
Regards,
Nigel Berjak
Please consider the environment before printing this email.
On 2025-03-14 19:48, Andrea Giudiceandrea via QGIS-User wrote:
> Il 14/03/2025 15:38, Jochen Albrecht ha scritto:
>> Thank you, Andrea. But let me reiterate that the layer is projected,
>> so the default should in either case be to apply the algorithm.
>> $area does not allow me to specify projection parameters. But by
>> playing with that option for the other tool, I found that the
>> erroneous value is based on ellipsoidal calculations - regardless of
>> whether a planimetric project CRS has been defined or not.
>> Can you think of a way to override this behavior for $area?
> Hi Jochen,
> not sure to understand your question.
> Area and length measurements can be performed either on the Cartesian
> plane of the CRS or on the ellipsoid.
> If a valid ellipsoid is the for the project [1], then the "$area"
> function calculates the area on such ellipsoid, regardless of whether
> the layer's or the project's CRS is a geographic or projected one.
> If the ellipsoid is set to "None/Planimetric", then the "$area"
> function will return the value of the area measured on the layer's CRS
> Cartesian plane (regardless of whether the layer's or the project's CRS
> is a geographic or projected one).
> Instead, the "area" function always calculates the value of the
> planimetric area measured on the layer's CRS Cartesian plane
> (regardless of whether the layer's or the project's CRS is a geographic
> or projected one and regardless a valid ellipsoid is the for the
> project).
> Thus, if you want to calculate the planimetric area on the Cartesian
> plane of the layer's CRS using an expression, then you can just use the
> "area" function. For the same purpose, you can also use the "$area"
> function, ensuring the project's ellipsoid is set to
> "None/Planimetric".
> Regards.
> Andrea
> [1]
> https://docs.qgis.org/3.40/en/docs/user_manual/introduction/qgis_configuration.html#general-properties
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User
