[Qgis-user] Remote Access by Multiple Users
Andreas Neumann a.neumann at carto.net
Wed Mar 19 00:28:55 PDT 2025
Hi Stewart,
For Multi-User data editing I definitely recommend using PostgreSQL (the
server should be in the same LAN than the clients editing). Geopackage
isn't designed for multi-user editing. Two users using Geopackage "read
only" should work though.
The QGIS project can be stored in Geopackage or PostgreSQL, but is
normally a separate file (.qgz or .qgs). The project file doesn't store
the geodata but only the references to the files, databases or web
services as well as any configuration and styling.
Hope this helps,
Andreas
On 2025-03-18 18:05, Stewart Galloway via QGIS-User wrote:
> I have data stored on a municipal server.
> Can I have two users, each on their own computer, access the same .QGS
> project file (as well as the same data on the municipal server)?
> Is that what a GeoPackage is for?  Or is Geopackage just for the data
> and not for the project file (QGS)?
> Or do I use PostgreSQL?
> Thanks.
> Stewart
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250319/741f4a07/attachment.htm>
More information about the QGIS-User mailing list
