[Qgis-user] Remote Access by Multiple Users
Andreas Neumann andreas at qgis.org
Wed Mar 19 05:44:56 PDT 2025
Hi Greg,
On Wed, 19 Mar 2025 at 13:33, Greg Troxel via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Andreas Neumann via QGIS-User <qgis-user at lists.osgeo.org> writes:
> > For Multi-User data editing I definitely recommend using PostgreSQL
> > (the server should be in the same LAN than the clients
> > editing).
> By 'same LAN', do you mean "same Ethernet, meaning no IP routing" or
> just "on the same premises so you have Gigabit speed and only a few
> milliseconds of latency"?   I would expect that it is only performance
> that matters, and several-ms gigabit-speed is fine.
It is mainly an issue of "latency", but also bandwidth. There are a lot of
SQL queries between QGIS and PostgreSQL. Every zoom and pan means several
SQL queries. If the latency is bad, then it isn't a lot of fun to work with
a remote PostgreSQL server.
In a case where the PostgreSQL server is at another company location with a
high latency in between than it should be considered to use more than one
PostgreSQL server and replication between the servers, in order to offer a
low latency to all QGIS clients.
> I am also curious how well it works if say the pgsql server is 80 ms RTT
> away, with a link such that one can get 2 MB/s usually.   I realize it's
> going to be slower, but I'm interested in hearing experience.
> > Geopackage isn't designed for multi-user editing. Two users using
> > Geopackage "read only" should work though.
> Even worse, access to files across SMB, when the programs expect to do
> locking, is asking for trouble.
> > The QGIS project can be stored in Geopackage or PostgreSQL, but is
> > normally a separate file (.qgz or .qgs). The project file doesn't
> > store the geodata but only the references to the files, databases or
> > web services as well as any configuration and styling.
> When you do this, is it basically storing a blob with what would have
> been written to qgs in a table of projects?
yes
> What happens if multiple people try to use the same project?  Are
> changes by one person propagated back to others as they are opened?
> How are write-write conflicts handled?
There is no conflict handling. The one that writes last wins.
> Or is the norm that projects are opened readonly by most people, and
> rarely changed?
This depends of course on the workflow and situation. I don't think one can
make a general statement here.
Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250319/6413e19f/attachment.htm>
More information about the QGIS-User mailing list
