[Qgis-user] Geotiff JPEG compression in Graphical Modeller
Grant Boxer
boxerg at iinet.net.au
Sat Mar 22 03:05:12 PDT 2025
I am creating RGB images with Sentinel 2 imagery using the graphical
modeller and would like to use JPEG compression which reduces the image size
substantially. The image files are "Float32 - Thirty two bit floating point"
images. When I look at the compression options when saving the raster image
in the graphical modeller, I do not get a JPEG compression option. The JPEG
compression option is available if I click on the layer in the layers panel
and "Save Raster As" under the Create Options. Any thoughts on why I can't
select this in the graphical modeller options?
Cheers Grant
Perth, WAust
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250322/bbfebe7a/attachment.htm>
More information about the QGIS-User
