[Qgis-user] hub lines
Humberto Vargas Espinoza hvargas at correos.go.cr
Thu Mar 27 06:10:00 PDT 2025
Good morning.
I have the following question.
I have a number of georeferenced points and I need to generate a route with a road shape and have the optimal route created with all the points at once. There are a lot of points, and extensions from point to layer or layer to point aren't optional for me.
[cid:image001.png at 01DB9EE7.7D63AD40]
De: QGIS-User <qgis-user-bounces at lists.osgeo.org> En nombre de Richard McDonnell via QGIS-User
Enviado el: jueves, 27 de marzo de 2025 01:37
Para: Michael.Dodd <michael.dodd at open.ac.uk>
CC: qgis-user at lists.osgeo.org
Asunto: Re: [Qgis-user] hub lines
Hi Michael,
I believe what hat you are looking for is Network analysis. You can have a look HERE<https://protect.checkpoint.com/v2/r02/___https:/docs.qgis.org/3.40/en/docs/training_manual/vector_analysis/network_analysis.html___.YzJlOmNvcnJlb3NkZWNvc3RhcmljYXNhOmM6bzpiN2VhNTcyYzdmNmJlZDljYzEzYmM5YzZiMWQyMGFjZjo3OjJlNjM6MDdlMzI2NGMxMTZiZDZlNjRlZjUwY2JmYzQwZDQ0MDgzNWVhOTA5MTgyY2UzMGFmYjE4MzE0ZjQzYjg0N2ZhOTpoOlQ6Tg> which should help. Shortest Path is what you would be looking at.
Kind Regards,
Richard
Richard McDonnell MSc GIS, FME Certified Professional
Flood Risk Management - Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 46 942 2409
https://gov.ie/opw<https://protect.checkpoint.com/v2/r02/___https:/gov.ie/opw___.YzJlOmNvcnJlb3NkZWNvc3RhcmljYXNhOmM6bzpiN2VhNTcyYzdmNmJlZDljYzEzYmM5YzZiMWQyMGFjZjo3OmI0YWI6OTU3MTc2YzBjMjEyZjQ0N2EyZmNjMGZjODRlZTA4NTI5ZGRjNzgxMDc3ZTQ1Y2E5MTI3ZTIyN2Q0NzY0MzliMTpoOlQ6Tg>
To send me files larger than 30MB, please use the link below https://protect.checkpoint.com/v2/r02/___https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie___.YzJlOmNvcnJlb3NkZWNvc3RhcmljYXNhOmM6bzpiN2VhNTcyYzdmNmJlZDljYzEzYmM5YzZiMWQyMGFjZjo3OjUwMjM6MTI2NzBkYjA4NDAyMDJlMWMxYTRkNzMzYzYxMzkxMzhhYjA0Mzg3N2E4MTZhNjE3ZDNmZDRmNDViNDllYTE3Zjp0OlQ6Tg
Email Disclaimer: https://protect.checkpoint.com/v2/r02/___https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/___.YzJlOmNvcnJlb3NkZWNvc3RhcmljYXNhOmM6bzpiN2VhNTcyYzdmNmJlZDljYzEzYmM5YzZiMWQyMGFjZjo3Ojk3Y2Q6MzE5MzhjNmMzMGVjMmI2ZjZmNDJkMzNhMGJiZTkxYzkxNjI5Mjg0NjUxOTU3YmI1MTUyZThmYjcxNGY4OTQyODp0OlQ6Tg
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of Michael.Dodd via QGIS-User
Sent: 26 March 2025 17:54
To: 'qgis-user at lists.osgeo.org' <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] hub lines
I have produced a map with hub lines using the vector analysis tool but now want to analyse the lines themselves e.g. work out max/min/total distances from a node and not sure how to do this as the attribute table from the hub layer does not have the line related data. Presumably I have to add it to the table but not sure how to do that in this instance.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250327/855cc627/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250327/855cc627/attachment-0001.png>
More information about the QGIS-User mailing list
