[Qgis-user] GRASS error
boxerg at iinet.net.au boxerg at iinet.net.au
Sun Mar 30 05:40:33 PDT 2025
Hi Andrea,
Yes, the problem seems to be fixed now with the latest updates. Many thanks
Grant
-----Original Message-----
From: Andrea Giudiceandrea <andreaerdna at libero.it>
Sent: Sunday, 30 March 2025 7:46 PM
To: qgis-user at lists.osgeo.org
Cc: boxerg at iinet.net.au
Subject: Re: [Qgis-user] GRASS error
Hi Grant,
the error message comes from the "GRASS 8 (deprecated plugin)" core plugin. Are you using it? If you don't need it, you can disable it using the plugin manager in QGIS.
Anyway, the error message should not be displayed using the latest QGIS
3.42.1 on Windows from OSGeo4W.
Regards.
> boxerg at iinet.net.au boxerg at iinet.net.au Sun Mar 2 14:43:10 PST
> 2025
> I am running the latest release 3.42 and after a fresh QGIS install I
> get the following error message on start-up.
> "GRASS init error: Problem in GRASS initialization, GRASS provider and
> plugin will not work : Module built against version 8.4.0 but trying
> to use version 8.4.1. You need to rebuild GRASS GIS or untangle
> multiple installations."
More information about the QGIS-User mailing list
