[Qgis-user] Exporting editable type
Kobben, Barend (UT-ITC) b.j.kobben at utwente.nl
Tue May 6 00:52:29 PDT 2025
Sure, but that in almost all cases renders labels not as text strings (1 string for every label), but as text characters (1 character for every letter in a label)....
Barend Köbben
On 06/05/2025, 09:20, "DelazJ" <delazj at gmail.com> wrote:
While exporting, try with selecting the "Text export" option as "Always render labels as text"
<https://docs.qgis.org/3.40/en/docs/user_manual/print_composer/create_output.html#export-as-pdf> which points to
<https://docs.qgis.org/3.40/en/docs/user_manual/working_with_vector/vector_properties.html#render-labels-text>.
Regards,
Harrissou
Le 6 mai 2025 07:55:50 GMT+02:00, "Kobben, Barend (UT-ITC) via QGIS-User" <qgis-user at lists.osgeo.org> a écrit :
That has been a long-standing complaint of mine (once filed a bug 3975<https://issues.qgis.org/issues/3975> of which this was part). It’s now declared closed, but it still is not in my opinion, and I always use SVG export to achieve fulley editable text labels....
Barend Köbben
On 05/05/2025, 23:21, "QGIS-User" <qgis-user-bounces at lists.osgeo.org> wrote:
When I export maps to pdf , I need the labels to be editable and not broken up into individual letters. Is this possible?
Thanks in advance,
Joe LeMonnier
QGIS-User mailing list
QGIS-User at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250506/742733fb/attachment.htm>
More information about the QGIS-User mailing list
