[Qgis-user] Exporting editable type
Tobias Schula
geospatial at schula.org
Wed May 7 07:10:02 PDT 2025
On Wednesday, 7 May 2025, 16:03:26 CEST Kobben, Barend (UT-ITC) via QGIS-User
wrote:
> Sure, but that in almost all cases renders labels not as text strings (1
> string for every label), but as text characters (1 character for every
> letter in a label)....
For me it only works reliable, when exporting the labels completely plain. I
leave everything in the labeling settings in its standard configuration, don't
add any buffer, mask or transformation, then in the PDF export every label
gets exported as text object.
I also don't have any special blending or transparencies activated in maps
that I want to process further in Inkscape, since these options would often
force a rasterisation. If you want to process your maps in a graphics program,
do as little graphics design in QGIS as possible. I also often have to export
several layers separately, because both the PDF and the SVG export are messed
up when importing in Inkscape.
Best regards
Tobias A Schula
Forestry Expert
More information about the QGIS-User
