[Qgis-user] Installation plugin map segmenter : erreur DLL
tochi at nihon-eco-solar.com tochi at nihon-eco-solar.com
Thu Nov 6 15:57:27 PST 2025
ファイル名として使用禁止にはなっていませんが、特定の環境下では認識されない、誤認識される可能性があるようです。
私はこのような経験が無いので、情報のみの提供です。
滝沢 真一 tochi@
Sent: Friday, November 7, 2025 12:33 AM
To: tochi at nihon-eco-solar.com; 'celati Laurent' <laurent.celati at gmail.com>; 'qgis-user' <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Installation plugin map segmenter : erreur DLL
according to Google translate, Tochi wrote
Could it be that "~" is causing the problem?
On 11/5/2025 10:08 PM, tochi--- via QGIS-User wrote:
「~」が問題を起こしている可能性はありませんか?
滝沢 真一 tochi@
From: QGIS-User  <mailto:qgis-user-bounces at lists.osgeo.org> <qgis-user-bounces at lists.osgeo.org> On Behalf Of celati Laurent via QGIS-User
Sent: Thursday, November 6, 2025 3:15 AM
To: qgis-user  <mailto:qgis-user at lists.osgeo.org> <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Installation plugin map segmenter : erreur DLL
I work with QGIS 3.34.13-Prizren
I try to install the plugin Mapsegmenter : https://plugins.qgis.org/plugins/segmenter/
But when i try to enable the plugin via the plugin manager i obtain an error message :
Impossible de charger l'extension 'segmenter' provoque une erreur lors de l'appel à sa méthode classFactory()
ImportError: DLL load failed while importing lib: La procédure spécifiée est introuvable.
  File "C:\PROGRA~1/QGIS33~1.13/apps/qgis-ltr/./python\qgis\utils.py", line 423, in _startPlugin
    plugins[packageName] = package.classFactory(iface)
  File "C:\Users/lcelati/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\segmenter\__init__.py", line 26, in classFactory
    from .segmenter import Segmenter
  File "C:\PROGRA~1/QGIS33~1.13/apps/qgis-ltr/./python\qgis\utils.py", line 892, in _import
    mod = _builtin_import(name, globals, locals, fromlist, level)
  File "C:\Users/lcelati/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\segmenter\segmenter.py", line 58, in
    from sklearn.cluster import KMeans
  File "C:\Users\lcelati\AppData\Roaming\Python\Python312\site-packages\sklearn\__init__.py", line 73, in
    from .base import clone  # noqa: E402
  File "C:\Users\lcelati\AppData\Roaming\Python\Python312\site-packages\sklearn\base.py", line 20, in
    from .utils._missing import is_scalar_nan
  File "C:\Users\lcelati\AppData\Roaming\Python\Python312\site-packages\sklearn\utils\__init__.py", line 9, in
    from ._chunking import gen_batches, gen_even_slices
  File "C:\Users\lcelati\AppData\Roaming\Python\Python312\site-packages\sklearn\utils\_chunking.py", line 11, in
    from ._param_validation import Interval, validate_params
  File "C:\Users\lcelati\AppData\Roaming\Python\Python312\site-packages\sklearn\utils\_param_validation.py", line 17, in
    from .validation import _is_arraylike_not_scalar
  File "C:\Users\lcelati\AppData\Roaming\Python\Python312\site-packages\sklearn\utils\validation.py", line 21, in
    from ..utils._array_api import _asarray_with_order, _is_numpy_namespace, get_namespace
  File "C:\Users\lcelati\AppData\Roaming\Python\Python312\site-packages\sklearn\utils\_array_api.py", line 20, in
    from .fixes import parse_version
  File "C:\Users\lcelati\AppData\Roaming\Python\Python312\site-packages\sklearn\utils\fixes.py", line 421, in
    import pyarrow
  File "C:\PROGRA~1\QGIS33~1.13\apps\Python312\Lib\site-packages\pyarrow\__init__.py", line 65, in
    import pyarrow.lib as _lib
Version de Python : 3.12.7 (main, Oct 25 2024, 11:18:09) [MSC v.1938 64 bit (AMD64)]
Version de QGIS : 3.34.13-Prizren Prizren, 222b5995
Chemin Python :
C:\Users/lcelati/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\segmap
C:\Users/lcelati/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\TocTable-main
C:\Users/lcelati/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\terminus_processing
C:\Users/lcelati/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\dissect_dissolve_overlaps_sagang
C:\Users/lcelati/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\buffer_without_overlaps
C:\Users/lcelati/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\BoundaryDelineation/lib
C:/PROGRA~1/QGIS33~1.13/apps/qgis-ltr/./python
C:/Users/lcelati/AppData/Roaming/QGIS/QGIS3\profiles\default/python
C:/Users/lcelati/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins
C:/PROGRA~1/QGIS33~1.13/apps/qgis-ltr/./python/plugins
C:\PROGRA~1\QGIS33~1.13\apps\grass\grass84\etc\python
C:\Users\Default\Documents
C:\Program Files\QGIS 3.34.13\bin\python312.zip
C:\PROGRA~1\QGIS33~1.13\apps\Python312\DLLs
C:\PROGRA~1\QGIS33~1.13\apps\Python312\Lib\site-packages\win32
C:\PROGRA~1\QGIS33~1.13\apps\Python312\Lib\site-packages\win32\lib
C:\PROGRA~1\QGIS33~1.13\apps\Python312\Lib\site-packages\Pythonwin
C:\Users\lcelati\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\deepness\python3.1
QGIS-User mailing list
QGIS-User at lists.osgeo.org <mailto:QGIS-User at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251107/b1474635/attachment-0001.htm>
More information about the QGIS-User mailing list
