[Qgis-user] py expressions don't load automatically in the Custom section
Andrea Giudiceandrea
andreaerdna at libero.it
Sat Oct 4 10:31:18 PDT 2025
Hi JP,
the issue doesn't occur on my Windows 10 system running QGIS LTR 3.40.11.
The custom functions can be either saved in the QGIS project or in the
QGIS user profile (in the \python\expressions\ folder inside the current
QGIS user profile folder).
In the former case, the functions are automatically loaded when such
QGIS project is opened, while in the latter case, the functions are
automatically loaded when such QGIS user profile is used.
Normally there is no need to use any startup.py or __init__.py file.
Are you sure you are using the right QGIS project file or QGIS user
profile in which the functions were saved?
It would be useful if you indicated the exact QGIS version and Operative
System name and version used and exact step-by-step procedure you follow
to create and save the functions.
Regards.
Andrea
> dejardinjp at gmail.com dejardinjp at gmail.com
> Sat Oct 4 08:38:36 PDT 2025
> I've a few Python expressions encoded through the function editor within the
> field calculator.
> As I save and load them, they appear in the "Custom" section, but if I
> restart QGis the complete Custom section disappears from the panel and I've
> to reload the expressions.
> I tried to manage it with a startup.py or __init__.py, but it failed . Any
> idea ? THX
More information about the QGIS-User
