[Qgis-user] save a join between attribute and table in gpkg?
Mike Bundock mike at augview.net
Fri Oct 17 11:27:30 PDT 2025
hi
we had a similar issue in that we could not find a way of saving join
information.  The technique we ended up using was to extend the qml syntax
to support join field definitions, and use a small function to re-establish
joins correctly. This is really useful if the same sets of tables are used
in multiple projects.  Its simply a matter of loading the qml files using
the layer -> properties -> load style function.
We also use it as an easy method to define the join fields within other
applications such as Augview.   It means that UI behaviour within multiple
applications is consistent and only needs defining once.
hope that is helpful. If you want to use the same syntax, let me know & i
will send some documentation.
regards
*Mike Bundock*  |  CEO
Augview |  P O Box 125046, St Heliers, Auckland 1740, New Zealand
p: +64 9 575 5298 | m: +64 27 575 5298 | e: mailto:mike.bundock at augview.net
<mike.bundock at augview.net>| w: www.augview.net
Winner of Innovation & Commercialisation and Supreme Awards at 2014 NZ
Spatial Excellence Awards
Winner of Innovation & Commercialisation Award at 2014 Asia Pacific Spatial
Excellence Awards
On Fri, 17 Oct 2025, 11:13 pm Simon Dietmann via QGIS-User, <
qgis-user at lists.osgeo.org> wrote:
> Dear list,
> I am trying to export some feature classes inside a common gpkg that have
> attribute joins to a table that’s also stored in the same gpkg.  Afaics
> there is no possibility to store the information about the table join also
> inside the gpkg, is that correct?
> Is there a way to store (and share) the joins except sharing a .qgz file?
> Thanks for your advice,
> Regards
> Simon
> i.A. Simon Dietmann
> Projektleiter | Geograph
> PGNU Planungsgesellschaft Natur & Umwelt mbH
> Amtsgericht Frankfurt am Main, HRB 111938;
> Geschäftsführer: Dr. Benjamin Hill, Dorit Thurm, Sebastian Braun
> Hamburger Allee 45 +++ 60486 Frankfurt am Main
> <https://www.google.com/maps/search/Hamburger+Allee+45+%2B%2B%2B+60486+Frankfurt+am+Main?entry=gmail&source=g>
> Durchwahl: +49 69 952964-32 +++ Fax: +49 69 952964-99
> E-Mail: dietmann at pgnu.de +++ Web: www.pgnu.de
> > Diese E-Mail könnte vertrauliche und/oder rechtlich geschützte
> Informationen enthalten. Wenn Sie nicht der richtige Adressat sind oder
> diese E-Mail irrtümlich erhalten haben, informieren Sie bitte sofort den
> Absender und vernichten Sie diese Mail. Das unerlaubte Kopieren sowie die
> unbefugte Weitergabe dieser Mail sind nicht gestattet.
> > This e-mail may contain confidential and/or privileged information. If
> you are not the intended recipient (or have received this e-mail in error)
> please notify the sender immediately and destroy this e-mail. Any
> unauthorised copying, disclosure or distribution of the material in this
> e-mail is strictly forbidden.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251018/ab4b45c8/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251018/ab4b45c8/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251018/ab4b45c8/attachment-0003.png>
More information about the QGIS-User mailing list
