[Qgis-user] save a join between attribute and table in gpkg?
Mike Bundock mike at augview.net
Fri Oct 17 12:59:51 PDT 2025
there can be issues with views, especially if the resulting field list is
long.  Where there is limited screen space, it seems more natural to follow
a join field.
*Mike Bundock*  |  CEO
Augview |  P O Box 125046, St Heliers, Auckland 1740, New Zealand
p: +64 9 575 5298 | m: +64 27 575 5298 | e: mailto:mike.bundock at augview.net
<mike.bundock at augview.net>| w: www.augview.net
Winner of Innovation & Commercialisation and Supreme Awards at 2014 NZ
Spatial Excellence Awards
Winner of Innovation & Commercialisation Award at 2014 Asia Pacific Spatial
Excellence Awards
On Sat, 18 Oct 2025, 8:19 am John Stevenson - BGS, <jostev at bgs.ac.uk> wrote:
> We have also had success with views.  There are a few queries to run to
> register them correctly.  You can do this via the QGIS Database manager.
> DB Browser for SQLite is also good.  Note that the view must include an
> integer ID to render correctly in some settings.
> CREATE VIEW IF NOT EXISTS "view_locality_geology" AS
>   SELECT
>     loc.fid as fid,
>     loc.name as name,
>     loc.rock_type,
>     geo.minerals as colour,
>     geo.age as age,
>     loc.geometry as geometry
>   FROM locality as loc
>     LEFT JOIN geological_units geo on geo.rock_type= rock_type;
> INSERT INTO gpkg_contents
> VALUES('view_locality_geology,'features','view_locality_geology','View
> with geology information at locality
> positions','2023-09-15T13:21:52.679Z',NULL,NULL,NULL,NULL,4326);
> INSERT INTO gpkg_geometry_columns
> VALUES('view_locality_geometry','geometry','POINT',4326,1,0);
> *From:* QGIS-User <qgis-user-bounces at lists.osgeo.org> *On Behalf Of *Mike
> Bundock via QGIS-User
> *Sent:* 17 October 2025 20:28
> *To:* Simon Dietmann <dietmann at pgnu.de>
> *Cc:* qgis-user <qgis-user at lists.osgeo.org>
> *Subject:* Re: [Qgis-user] save a join between attribute and table in
> gpkg?
> hi
> we had a similar issue in that we could not find a way of saving join
> information.  The technique we ended up using was to extend the qml syntax
> to support join field definitions, and use a small function to re-establish
> joins correctly. This is really useful if the same sets of tables are used
> in multiple projects.  Its simply a matter of loading the qml files using
> the layer -> properties -> load style function.
> We also use it as an easy method to define the join fields within other
> applications such as Augview.   It means that UI behaviour within multiple
> applications is consistent and only needs defining once.
> hope that is helpful. If you want to use the same syntax, let me know & i
> will send some documentation.
> regards
> mailto:mike.bundock at augview.net <mike.bundock at augview.net>| w:
> www.augview.net
>      [image: Image removed by sender.][image: Image removed by sender.]
> On Fri, 17 Oct 2025, 11:13 pm Simon Dietmann via QGIS-User, <
> qgis-user at lists.osgeo.org> wrote:
> Dear list,
> I am trying to export some feature classes inside a common gpkg that have
> attribute joins to a table that’s also stored in the same gpkg.  Afaics
> there is no possibility to store the information about the table join also
> inside the gpkg, is that correct?
> Is there a way to store (and share) the joins except sharing a .qgz file?
> Thanks for your advice,
> Regards
> Simon
> i.A. Simon Dietmann
> Projektleiter | Geograph
> PGNU Planungsgesellschaft Natur & Umwelt mbH
> Amtsgericht Frankfurt am Main, HRB 111938;
> Geschäftsführer: Dr. Benjamin Hill, Dorit Thurm, Sebastian Braun
> Hamburger Allee 45 +++ 60486 Frankfurt am Main
> <https://www.google.com/maps/search/Hamburger+Allee+45+%2B%2B%2B+60486+Frankfurt+am+Main?entry=gmail&source=g>
> Durchwahl: +49 69 952964-32 +++ Fax: +49 69 952964-99
> E-Mail: dietmann at pgnu.de +++ Web: www.pgnu.de
> > Diese E-Mail könnte vertrauliche und/oder rechtlich geschützte
> Informationen enthalten. Wenn Sie nicht der richtige Adressat sind oder
> diese E-Mail irrtümlich erhalten haben, informieren Sie bitte sofort den
> Absender und vernichten Sie diese Mail. Das unerlaubte Kopieren sowie die
> unbefugte Weitergabe dieser Mail sind nicht gestattet.
> > This e-mail may contain confidential and/or privileged information. If
> you are not the intended recipient (or have received this e-mail in error)
> please notify the sender immediately and destroy this e-mail. Any
> unauthorised copying, disclosure or distribution of the material in this
> e-mail is strictly forbidden.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> This email and any attachments are intended solely for the use of the
> named recipients. If you are not the intended recipient you must not use,
> disclose, copy or distribute this email or any of its attachments and
> should notify the sender immediately and delete this email from your
> system. UK Research and Innovation (UKRI) has taken every reasonable
> precaution to minimise risk of this email or any attachments containing
> viruses or malware but the recipient should carry out its own virus and
> malware checks before opening the attachments. UKRI does not accept any
> liability for any losses or damages which the recipient may sustain due to
> presence of any viruses.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251018/a12291db/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251018/a12291db/attachment-0002.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251018/a12291db/attachment-0002.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251018/a12291db/attachment-0003.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251018/a12291db/attachment-0003.png>
More information about the QGIS-User mailing list
